Old 09-13-2024, 12:50 PM   #1
kna4977
Correct screws for automatic column shift indicator housing?
What are the correct screws for the shift selector housing that sits on the column and where can I get them?
kna4977 is offline   Reply With Quote
Old 09-13-2024, 01:21 PM   #2
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: Correct screws for automatic column shift indicator housing?
The transmission control pointer assembly’s red plastic shift indicator slides into its plastic housing. The housing’s tabs twist into the shift lever housing’s top hole, and mounts with one stainless #1 phillips countersunk oval head self-drilling screw. The screw threads are #8 x 5/16".
The transmission control dial assembly’s (shift indicator) plastic lens inserts into its plastic housing. The housing mounts onto the turn signal housing’s top with two stainless #1 phillips countersunk oval head self-drilling screws. The screw threads are #8 x 5/16".
Standard P/U screws may have been phosphate. If you're a paying member you can find originals on the parts board. Seems there would be replacements available, but sometimes replacement screws are junk, and pretty much always inferior OEM.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
