#76 |
The Older Generation
Re: Slow Progress is better than No Progress.
Yep, I like it.... ![]() .
#77 |
Ohhh that's going to be so great! Can't wait to see the finished headliner.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#78 |
Active Member
![]() Join Date: May 2022
That's beautiful workmanship. I notice some fabric in one of the photos, is that what you're going to back it with?
#79 |
#80 | |
Woody |
#81 | |
Woody |
#82 |
Man, that is going to look killer once it’s all wrapped up. Very nice
#83 |
#84 |
#85 |
Here’s a couple pictures of the fabric loosely laid over the top of the front panel…not stretched tight or fastened yet. Also a glimpse of the stain color, however, it hasn’t been clear coated yet because I’m still deciding between satin or semi-gloss?
Woody |
#86 |
Man, that looks like a lot of labor intensive work. Good job all around..... ![]() .
#87 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
x2
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
#88 |
Thanks Leon and Dale…the long side-rails (3” wide with compound angles ripped the entire length) are being worked on right now, then on to the front cap!
Woody |
#89 |
Sorry for the “Slow Tease” but my woodworking friend had some work of his own to take care of, plus, a couple of his key pieces of equipment needed unexpected repairs…and as he uses the really good vintage type stuff, it was hard to find parts! Things should start up again on Monday (hopefully!).
In the meanwhile, I have been dialing in the A/C cover wood panels…and I think it came out pretty good! I can’t attach the fabric yet, as we will have to do all the panels at the same time to get proper alignment of the palm tree design, but other than that, it’s done! I installed “Rivnuts” for all my attachment points, which allows for easy installation and removal of the individual panels. The A/C cover section has the two “mirror image” sides plus the full width cap…all held firmly in place with just three stainless steel machine screws with beauty washers, which gives a nod to to original headliner. I do have plans to “clean-up” the plastic A/C cover…but haven’t decided if it will just get painted or dipped with an “appropriate” beach-themed pattern? I’m also planning to make wooden slat type vent covers to replace the plastic ones that disintegrated long ago! Ideas just keep popping into my head! Woody |
#90 |
Always looking forward to updates on your suburban. That woodwork is going to look killer all complete
#91 |
I can't wait to see it finished. I think it going to look great!!
#92 |
#93 |
#94 |
Here’s my start for the A/C cover vents…not sure where I’m going from here, but at least I have a base to work off of!
Woody |
#95 |
BlahBlahBlah
How's the burb coming along?
#96 |
Thanks for asking, CG…I have one last hurdle to jump before installing the headliner wood “WITH FABRIC” before I’ll post another picture! Hopefully, my seats will be reinstalled at the same time so I can start working on the drivability aspect!
Wishing you and everyone in the group a Merry Christmas and a Happy New Year! Woody Last edited by Beach-Burban; 12-20-2024 at 06:57 PM. |
#97 | |
You and your family have a great holiday too Woody...
#98 |
Happy Holidays back to you fine folks too!
Woody, we're all looking forward to the headliner updates. And CG I saw your panel on Craigslist but, before I could get it added to the found for sale thread it disappeared. Did you sell it? Sorry for the highjack. MERRY CHRISTMAS!
#99 |
Well I finally found sometime to get working on the headliner again...I won't say it's 100% done, but the finishing touches will not require removing any of it again (whew!). I have about 4 dozen filler strips that need to be cut to size, stained then glued in between the runners above the caps to give a smoother more finished look. Had I just stained all of it ahead of time, I would've been fine with how it is currently, but now I'm committed (or should be committed...to the looney bin!). I haven't reinstalled any of my "surfboard seats" because I am also working on a different (non-suburban) project and I need to haul some 4x8 sheets...so the Beach Burban is pulling double duty right now! I've taken enough pictures of my headliner project to make a tutorial when I actually do finish...but the first sentence of that would be "Don't do it the way that I did it...I just seemed to complicate a lot of the steps!" I am thrilled with the results...but I did make it more difficult than it should have been!
I'll post more "slow progress" again (hopefully quicker than my normal speed). Woody In case you can't read it, the surfboard above the mirror says "Beach Burban". The A/C vent covers were a "trial run" as the cuts aren't sharp enough. Happy with how the dome light came out. The map lights work well for the cargo area. Not a great picture, but gives an idea on the overall feel. |
#100 |
WOW!!!!! The results are worth all of your efforts!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Absolutely outstanding and I'm sure the photos aren't doing it justice.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
