![]() Join Date: Jan 2010
A/C heater core box restoration question
An original heater core box inside the cab. I cleaned it but you can still see the white-ish marks from ppl hitting it with their feet. Can this be polished up to look new again? What products have you used? I really don't want to paint it.
Re: A/C heater core box restoration question
Also when it's wet all the scratches appear to dissappear. . Just not when it's dry
I actually just got some maguires plastic cleaner. It did the job I was looking for!
I used a satin clear.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed |
![]() Join Date: Nov 2001
I used a very fine sandpaper to wet sand on a very faded box, took some time on the nooks and crannies then clear coated over the natural surface. Maybe not a hundred percent factory looking dude to the clear coating, it's very clean and looks good very close to original, i also think I used a satin clear
NGN Nick. |
![]() Join Date: Jun 2022
Good idea. I was thinking clean/polish rather than anything abrasive. Mine looks like that too
1970 C10 Custom longbed 350/350 Code:
__ ______|__]\____ ....|___(o)_____(o)_] |
![]() Join Date: Dec 1999
Sanded my box down to 400 grit and applied clear. All that is is needed. Results can be seen in my build thread.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
