09-22-2024, 07:14 AM | #3726 |
Re: PO has me PO'd
09-22-2024, 08:25 AM | #3727 |
Re: PO has me PO'd
image by [url=https://www.flickr.com/photos/97391199@N06
Just like my trunk of my ‘62 impala , no turquoise though Have to wait 2days for it to dry
09-25-2024, 11:00 AM | #3728 |
Re: PO has me PO'd
Next step 3 M 08115 body panel adhesive
image by [url=https://www.flickr.com/photos/97391199@N06 Must have used a can opener to cut
09-25-2024, 11:28 AM | #3729 |
Re: PO has me PO'd
Coating not as durable as expected failed wire brush test
09-26-2024, 10:46 AM | #3730 |
Re: PO has me PO'd
Before degreasing, deburring can wait as ppp smells volatile and sparks from dremel could have bad results
09-27-2024, 10:32 AM | #3731 |
Re: PO has me PO'd
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 09-27-2024 at 10:41 AM. |
09-27-2024, 04:41 PM | #3732 |
Re: PO has me PO'd
Failed the scratch test, tried putting paint on top, didn’t work
09-29-2024, 09:45 AM | #3733 |
Re: PO has me PO'd
09-29-2024, 10:17 AM | #3734 |
Re: PO has me PO'd
PPE required dust may be caustic or down right deadly
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 09-30-2024 at 09:11 AM. |
09-30-2024, 10:40 AM | #3735 |
Re: PO has me PO'd
After reading precautions I decided to try a file and keep the dust as minimal Using a rat tail lends itself to follow the contour of the sheet metal sort of gauging out an area to be filled later with?
10-01-2024, 11:59 AM | #3736 |
Re: PO has me PO'd
Second application Trying plug weld lower left
10-01-2024, 12:54 PM | #3737 |
Re: PO has me PO'd
I would stick to the panel bond for gluing 2 pieces together.
Then switch to the tiger hair for filling in the low spots. I am going to guess less then favorable results filling in the bolt holes. Probably best to glue small patches underneath and tiger hair over top. |
10-02-2024, 12:21 AM | #3738 |
Re: PO has me PO'd
You can tool the panel bond out with a body filler squeegee. Just like you would with glazing putty. That should reduce the amount of sanding and reapplying you need to do. Depending on ambient temps it can definitely feel thicker/stickier than glazing putty. But, it still spreads out fairly well.
If you want to fill those screw holes with it. Chamfer both sides of the holes you want to fill. And clean the the surrounding area to bare metal with a 36 grit disk. Just like when you're bonding two body panels together. Then fill the holes and spread a thin skim coat of the panel bond over the top. If you do any finish sanding afterwards. There should still be a skim coat of panel bond surrounding the holes. I would not do this for any exterior body panels. Last edited by Grounded63; 10-02-2024 at 12:32 AM. |
10-02-2024, 08:31 AM | #3739 | |
Re: PO has me PO'd
10-02-2024, 08:36 AM | #3740 | |
Re: PO has me PO'd
Are you saying not to use this product to hang body panels, because that was my main purpose to try it out
10-02-2024, 10:18 AM | #3741 |
Re: PO has me PO'd
No, it's made for hanging ( mostly non structural ) body panels. Gluing some pinch seams together in place of spot welding.
But, it shouldn't be used like a filler or have an exposed Seam in the middle of a exterior painted panel. Like if it was used to fill the roof to B pillar lead seam on a car. Or like a partial lower quarter panel replacement that was flanged. If the panels were panel bonded at the flange and the seam was filled in with panel bond. Then just sanded flat, epoxied, 2k surfacer, blocked, sealed, top coated, cleared. That " exposed " panel bond Seam has a tendency to " shadow " through the primer/top coats. |
10-03-2024, 06:52 AM | #3742 | |
Re: PO has me PO'd
10-04-2024, 06:13 AM | #3743 |
Re: PO has me PO'd
10-04-2024, 07:55 PM | #3744 |
Re: PO has me PO'd
I see you are selling some of your stuff from this like the half top, hopefully everything is alright?
10-06-2024, 02:39 PM | #3745 | |
Re: PO has me PO'd
I just ran out of money to finish the truck I may even sell my speed minder, tach, 60pound oil gauge cluster, tilt column to finance the project, but I hope it doesn’t come to that…… Tags inspection, insurance
10-07-2024, 11:24 AM | #3746 |
Re: PO has me PO'd
Using texture and color to hide my lack of body work skills
1st coat image by [url=https://www.flickr.com/photos/97391199@N06
10-07-2024, 08:53 PM | #3747 |
Re: PO has me PO'd
[quote=jaros44sr;9345730]Using texture and color to hide my lack of body work skills
1st coat image by [url=https://www.flickr.com/photos/97391199@N06[/quote] looking better
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
10-08-2024, 09:32 AM | #3748 |
Re: PO has me PO'd
is that motor running yet?
Lends itself to matching with deburring tool image by [url=https://www.flickr.com/photos/97391199@N06
10-09-2024, 10:48 AM | #3749 |
Re: PO has me PO'd
10-11-2024, 08:55 AM | #3750 |
Re: PO has me PO'd
Sometimes you just can’t drill a hole and a punch is a better method
image by [url=https://www.flickr.com/photos/97391199@N06 Closing in on 800,000, thank you for all the support
