10-06-2024, 02:10 PM | #1 |
POA valve test?
Wanting to test the POA valve. I have the line off the expansion valve. Is it mandatory to disconnect the line from the back of the POA valve or if so is there another place I can disconnect a line to check it? I can’t seem to get it loose there and don’t want to break anything.
10-06-2024, 03:38 PM | #2 |
Re: POA valve test?
The search engine on this forum is your best friend...try it, you'll like it.
https://67-72chevytrucks.com/vboard/...ting+poa+valve Read this first....https://www.originalair.com/about-poa-valves |
10-06-2024, 05:28 PM | #3 | |
Re: POA valve test?
10-07-2024, 01:26 AM | #4 |
Re: POA valve test?
Has anyone attempted to use a thermostat switch to monitor the evaporator temp and cycle the A6 compressor to avoid freezing? Is cycling a A6 advisable? Looks like Original Air is not rebuilding POA valves anymore and now offering valve and a Thermostat switch. I was under the impression cycling a A6 was not a good idea.
10-07-2024, 08:41 PM | #5 | |
Re: POA valve test?
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
10-10-2024, 11:43 AM | #6 |
Re: POA valve test?
POA valve tested good and I adjusted the pressure down to 27. I'm in the process of charging the A/C system. I've just about got it fully charged. Pressures are great at first and the air from the vents is cool, but as the vehicle heats up and I continue to charge, the pressure on the high side keeps climbing to where I'm not comfortable with it. Between 225 and 250 so I shut it down. Is this an air flow issue or likely something else like a blockage? I do know I currently have an air flow issue which I'm addressing as well just waiting on parts. Has a 4 blade fan and no clutch when it should have a 7 blade and a clutch. I've vacuumed and resealed the system. Has no leaks. I'm about half a can of R134 from a full charge. Temps from the vents don't seem to change, but as pressures seem to rise, the engine seems to struggle more.
10-10-2024, 01:07 PM | #7 |
Re: POA valve test?
Try cooling down the condenser with water, like the garden hose. You definitely need a lot of air flow with 134
250psi isn't out of sight with 134, it does run higher pressure on the hi side than R12. What's your fill amount? Generally you want 80% of the R12 amount as a starting point. When I converted my POA system in my 68 Cadillac it would run hi side pressures like that at a stop. I added a pusher fan and it helped but I really needed a parallel flow condenser.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ Last edited by clay68c10; 10-10-2024 at 02:24 PM. |
