El Camino inner tie rod for conversion question
I've seen a couple threads talking about this, and wanted to verify if it's accurate. While converting my 67 C20 to a C10, instead of using a 67 outer tie rod as an inner, and using a squarebody outer tie rod with the POL sleeve adapter in the middle, I could use a 75 ish El Camino inner tie rod and squarebody outer tie rod with a normal adjusting sleeve. Is this correct? It's just that simple? FYI, my C20 centerlink is from a manual steering setup if that makes a difference.
![]() ![]() Join Date: Jul 2002
Re: El Camino inner tie rod for conversion question
When I did my disk brake/spindle conversion, )a 78 c10) I just used the power steering cross link, idler arm and pitman arm as well as all 4 Tie rods and the sleeves from a 78. It made it easier for replacements. I knew the whole front end was 78 if I ever needed any parts
#3 | |
I have not ueard anyone using the chevelle/el camimo tie rod asyou described. Always v10s if the different eras
I missunderstood your question. Thus my previous answer.
I've never done the conversion you're doing, so perhaps I don't know what I'm talking about... But here goes..
Starting point ---- 1967 C/20 Ending point ----- 1967 C/10 C/10 springs and shocks Couldn't you change the ball joints to C/10s?? Install 71-72 C/10 spindles (disk brakes) Install 71-72 C/10 center link, idler arm, and Pittman arm 71-72 tie rods - inner, outer, sleeve.. |
![]() Join Date: Jul 2007
Here is a rock auto comparison between the two. I finally found the ones with the most usable info. I've never heard of that swap but the last time I had a 67/72 C 10 was 1989 and I'd have to look on the title to see how long I have had my 71 GMC 3/4 ton although it did cross my mind to to make a short box 1/2 ton out of it but it will tow my boat and car trailer as is.
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 10-21-2024 at 12:00 AM. |
