10-24-2024, 01:43 PM | #1 |
Need source for correct dash speaker
I cleaned up my original radio and got it working. No parts needed. Just some good cleaning. My original 10 ohm factory dash speaker has an open circuit so it will not work. Searching, results returns modern speakers with way to low of resistance that will damage the radio's power transistors over time. Is there a source for a correct speaker or possibly a repair service?
10-24-2024, 02:05 PM | #2 | |
Re: Need source for correct dash speaker
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
10-24-2024, 02:11 PM | #3 | |
The Older Generation
Here is their new web site: https://www.smelectrotech.com/ I had 2 original speakers re-coned by Jackson Speaker Service, Jackson, Michigan. they did a nice job on them. At that time they didn't have a web site or FB account but they may have now. I just typed the name into Google and called them from the info on there. LockDoc
10-24-2024, 04:04 PM | #4 |
Perfect thank you
As usual. 5 mins after posting I located a repair shop about an hour from me. But his cost to repair and shipping would be more than the replacement unit on the site you both recommended. Plus I won't have to wait 2 weeks while he repairs. Great referral. Thanks again. |
10-24-2024, 05:11 PM | #5 | |
Post back and let us know how you get along with it. .
10-26-2024, 10:06 PM | #6 |
I strung together two cheap 4 Ohm speakers in series for an 8 Ohm load
1970 C10 Custom longbed 350/350 Code:
__ ______|__]\____ ....|___(o)_____(o)_] |
10-27-2024, 12:57 AM | #7 |
I was tempted to do the same. Bach in the day 8 ohms would probably work for years. 50 years later, I feel the load may over tax a component that at one time not been an issue. Given it seems not too difficult to source a 10 ohm speaker, I'll go the conservative route.
10-27-2024, 02:27 AM | #8 | |
11-04-2024, 03:03 PM | #9 |
Follow up on Speaker received from https://www.smelectrotech.com/
Took about a week. Sent USPS. About 98 buck shipped. I failed to take a picture before I placed the mount on the speaker. Stated made in USA Speaker is as close as its going to get with modern parts available. The new speaker has a very small magnet and at first look concerning to me. The vendor states the magnet thou smaller is actually much stronger than original using more modern material. There is a plastic block to attach to the speaker magnet so that the original mounting hardware can be used. The Speaker works well and included clear instructions and informative. I would not have been concerned about polarity had I not read the instructions. On a mono set up, polarity should not normally be an issue but in this case there appears to be a need. The speaker cone jumps upon power up of the radio. The cone should jump out not pull back when the radio is turn one. How many of you knew that little tid bit? The lead is the original from original speaker. One more point. The felt is included on face of speaker. No chasing down extra needed items on this one. Very much worth the price. Last edited by PbFut; 11-04-2024 at 03:06 PM. Reason: pic upload |
11-05-2024, 08:17 PM | #10 |
Interesting. Is there a reason behind the cone should jump out not pull back when the radio is turned on? Should it jump towards the felt, is that the idea?
It looks like their online selector picks an oval speaker instead of special rectangle when you choose 1969. Other years give the speaker shape you show, special rectangle. Last edited by dmjlambert; 11-05-2024 at 08:29 PM. |
11-05-2024, 08:51 PM | #11 |
I put one of those speakers from https://www.smelectrotech.com (formerly turnswitch.com) in my 74 Nova about 10 years ago and it still sounds great. Back then they supplied a little wooden block (instead of plastic) to fit over the smaller magnet and make it secure in the factory mounting bracket.
The amplifier circuit in many of the original Delco radios (typically the ones that use a DS501 or DS503 output transistor) place a small DC bias (about 1.3 to 1.5V) across the speaker. That's what causes the speaker cone to move up and create that pop/click sound when the radio is switched on. If the polarity were reversed I think it could have the potential (depending on the speaker design) to pull the cone down close enough to the magnet that it might momentarily bottom out and distort the sound. |
11-06-2024, 08:13 AM | #12 |
I have their speakers in my Blazer using a modified van AM/FM with rear speaker fader option, with second speaker mounted in the center console. The sound is very good for a totally vintage radio, and the fit was good in the original speaker grille.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
