Old 06-16-2002, 08:29 AM   #1
dandeluxer
Guest
Posts: n/a
battery draining problem
my battery keeps draining, what is the easiest way to troubleshoot what is draining it . ive got a volt- ohm meter
Old 06-16-2002, 08:47 AM   #2
Zkast
Zkast's Avatar
Originally posted by REPO1
Here is how you check it. Disconnect the negative battey terminal. Put a test light in between the battery terminal, and the cable. (in series)
Now if you have a battery drain, the light is going to be on. Now start disconnecting things, like your alternator, and start pulling fuses, 1 by 1. Eventually the light will go out when you pull the right fuse, or pull off the right wire. Just keep an eye on the test light, and do one at a time.
That is the quickest way to narrow it down.
(had a friend that couldn't find his drain, I showed him that, and we found it in 2 mins. Damn aftermarket electric choke.)
Hope this helps ya!
Reid
Sylvan Lake, Alberta, Canada
1970 Chevy C20 Custom Camper
#s matching 402BB Turbo 400 trans.
Air conditioning, power steering, manual brakes.
73,600 Original Miles!!
(Add on 2000 more from raod trip!)
Thats the ticket right there! Great instructions.
Zkast is offline   Reply With Quote
Old 06-16-2002, 09:45 AM   #3
da-burb
"Ochre Ogre"
da-burb's Avatar
That is the way to do it.
You can also do it from under the dash. Pull the fuse out. Now on the fuse holder, touch the aligator clip to one side and the point of the test light to the other side of the fuse clip. Make sure that you have everything off (like the dome light, aftermarket radio with a clock)when you are doing this. It will light when you find the circuit that has the short.
Now, does your horn work? I can't tell you how many dead batterys after 3 days I have had because the horn relay has gone bad. If you don't have a working horn, start there.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
