Old 06-11-2024, 11:17 AM   #251
straight6chevyguy
straight6chevyguy's Avatar
Re: My New Truck
You'll have have to set your video's settings to ether public or unlisted for us to be able to see it. Unless you can figure out how to share a private video I have never done it so I don't know how it works on those.
Unlisted usually is the best way to go if you want to share a video but don't want it coming up in the YouTube search results.
1965 Chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 Chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1978 Chevy c20 350 4speed
1998 Chevy c1500 4.3L 5speed
1999 Chevy k1500 Suburban 5.7L auto 4x4
2002 Chevy s10 4.3L auto 4x4
1971 Mercury Monterey wagon 400 auto
Plus other misc. ... To many projects!
straight6chevyguy is offline   Reply With Quote
Old 06-11-2024, 03:47 PM   #252
Factory Guy
Factory Guy's Avatar
Re: My New Truck
Thanks for the heads up! Sorry about that, I just fixed it.
Factory Guy is offline   Reply With Quote
Old 06-12-2024, 01:30 AM   #253
straight6chevyguy
Re: My New Truck
Fired right up! Sweet
Old 06-12-2024, 10:01 AM   #254
SCOTI
SCOTI's Avatar
Re: My New Truck
Video worked.
I know you mentioned & swapped the cam but I never noticed the details/specs regarding your choice. What did you go with?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-14-2024, 01:05 PM   #255
Factory Guy
Re: My New Truck
Originally Posted by SCOTI View Post
Video worked.
Sorry i got busy building the engine and the truck never got around to putting up the cam. Cam shaft is the TRUE SLOPPY stage 2 cam from Matt Happel. He has kinda pioneered dropping LS engines into about everything and then racing them.
Its a moderately priced cam. You can read more about it in the link below. Warning it you do a camshaft like this you WILL need a stall converter!
https://sites.google.com/site/sloppy...sloppy-stage-2
Chev Gen III/IV (LS Series) 3-Bolt '97-Present
Adv. Duration: 283/286
Duration @ .050": 228/230
Lift: .585/.585
Lobe Separation: 112 LC
If you run this can you do not need to change the pushrods. Only the valve springs need to be changed to the PAC1218’s.
Old 06-14-2024, 01:17 PM   #256
Factory Guy
Re: My New Truck
Originally Posted by hewittca View Post
I'm following along to see how that air intake setup comes together. I have one of those "filter on a tube" intakes and don't really like the look or sound of it as it sucks in air. I also like that frame stiffener for the steering box. I've never seen that before.
Hopefully in the next several weeks i will post up the cold air intake as it is done (just havenÂ’t gotten to posting it.
Old 06-15-2024, 09:37 PM   #257
Factory Guy
Re: My New Truck
Ok, on the cold air intake here is what I did. I took the factory Silverado air box (2001-2007). And I just modified it. I took off the outside cold air intakes where the Silverado would get its cold air from. I plugged those as the stock Silverado cold air intake tubes popped right out. I had some old gm plastic parts laying around, so i cut the up to fill these old Silverado cold air intake tubes. Baking soda and SUPER GLUE make a real good filler/glue for this (albeit messy).
If you’re wondering why i just didn’t cut a hole in the rad support. That isn’t going to happen, as my rad support was in perfect condition after 50 years so I am not going to cut it up. So instead i will punch a hole in the aftermarket inner fender liners.
Old 06-15-2024, 09:57 PM   #258
Factory Guy
Re: My New Truck
So i just went to my local metal dealer and bought 4” aluminum tubes 24” long. (Didn’t really know how much I needed). I reset the air box in the right front corner of my Squarebody and after a lot of measuring and calculating i took the 4” hole saw and punched a hole in the bottom of the air box. I then used little “L” brackets to mock up where i wanted the tube. The bolts were later removed so air flow would not be restricted.
In the air box and on the outside of the air box any gaps i filled with a silicon type of caulk to make sure only the air outside the engine compartment is getting into this air box.
Old 06-15-2024, 10:21 PM   #259
Factory Guy
Re: My New Truck
For some reason this silver tube picture won’t save in the previous file.
Old 06-15-2024, 10:30 PM   #260
Factory Guy
Re: My New Truck
Not having much luck uploading photos tonight. Heres a few more.
Old 06-16-2024, 07:55 PM   #261
Factory Guy
Re: My New Truck
Here's some more of the air box...
Old 06-16-2024, 07:59 PM   #262
Factory Guy
Re: My New Truck
For the intake tube I used standard 4" aluminum tube from the local metal dealer. I scuffed it up real good with a scotch brite pad then painted it with some Duplicolor Truck bed liner. Nothing fancy here.
Old 06-17-2024, 01:01 AM   #263
straight6chevyguy
Re: My New Truck
I think it came out really nice!
Old 10-12-2024, 08:44 PM   #264
Factory Guy
Re: My New Truck
Many thanks to TKCR for the "new" 3 point seat Belts. I think they look pretty much like they were installed in this 1973 from the Factory...which was my goal!
Old 10-12-2024, 08:51 PM   #265
TKCR
TKCR's Avatar
Re: My New Truck
Holy smokes! Those look great in there!
Absolutely beautiful
Old 10-12-2024, 11:52 PM   #266
straight6chevyguy
Re: My New Truck
Nice!
Old 11-13-2024, 11:19 AM   #267
Factory Guy
Re: My New Truck
So I got the LS up and running. Yeah!
I got the base tune from Brendan at Lt1swap.com. But now I need to get a real tune done. Anybody know of a place in Kansas City that does LS ecu tuning?
Old 11-13-2024, 12:50 PM   #268
olrosa
olrosa's Avatar
Re: My New Truck
Email, Andrew, he can do it Mobily <projectgattago@gmail.com>.
He is great!
olrosa is offline   Reply With Quote
Old 11-13-2024, 12:55 PM   #269
SCOTI
SCOTI's Avatar
Re: My New Truck
He is great!
Does Andrew do GM stuff? I thought he was just doing Holley EFI tuning?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-13-2024, 06:02 PM   #270
olrosa
olrosa's Avatar
Re: My New Truck
Good point. I am not sure. I would email him. Its worth an ask.
Old 11-13-2024, 06:44 PM   #271
Factory Guy
Re: My New Truck
He is great!
I sent him an email! Thanks!
Old 11-13-2024, 10:02 PM   #272
SCOTI
SCOTI's Avatar
Re: My New Truck
Pretty sure he's strictly Holley based remote tuning. He's also in Texas now as well.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-08-2025, 03:47 PM   #273
Factory Guy
Re: My New Truck
Rear Sway Bar?
Anybody got a source for Rear FACTORY SWAY BAR Bushings?
Yes I have checked LMC Truck and Classic truck Parts of America (Riverside MO), Rock Auto and etc.
Yes the Rear Sway Bar, was installed at the factory by GM.
Old 01-08-2025, 05:48 PM   #274
Shifty One
Shifty One's Avatar
Re: My New Truck
What is the bar diameter?
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Old 01-09-2025, 11:05 AM   #275
SCOTI
SCOTI's Avatar
Re: My New Truck
My dually had one before the 4-bar/bags/Panhard bar swap. I don't recall anything special about the bushings so whatever OD the bar is should work.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
