Old 11-15-2024, 08:40 PM   #1
jmlloar
jmlloar's Avatar
Heater assembly diagram.
I'm looking for a diagram for the deluxe heater assembly. I have the parts manual for 55 to 59 GMC but the heater assembly is not listed in it. Chevy and GMC should be the same thing. Does anyone have a copy of it?
jmlloar is offline   Reply With Quote
Old 11-16-2024, 11:31 AM   #2
dsraven
Re: Heater assembly diagram.
here are a couple pics of the fancy heater. it draws outside air from the square hole in the cowl above the footwell vent. I sold this unit to a fella here who was very exited to get it. it worked fine and there were no leaks or strange noises. there is also a fancy heater control cluster somewhere in my old truck parts but that is another day of searching through boxes, not pics I thought I had tucked away. hope this helps you some.
Old 11-16-2024, 11:53 AM   #3
gmc jr van
1957 heater assembly diagram.
https://chevy.oldcarmanualproject.co...cpctai108.html
gmc jr van is offline   Reply With Quote
Old 11-16-2024, 12:16 PM   #4
jmlloar
jmlloar's Avatar
Originally Posted by gmc jr van View Post
Exactly what I needed. thanks.
So looks like all I am missing is the piece that attaches to the cab for air inlet just above the vent. Cab I have had a flat blockoff plate and a standard heater.
Old 11-16-2024, 12:26 PM   #5
dsraven
Do you have the custom heater? Honestly, if you don't have the original larger heater and want a little more you could look for an aux bus heater or a universal style unit and adapt that to fit and have more heat output than stock. The stock heaters generally weren't made for the higher system pressures of more modern cooling systems.
Old 11-16-2024, 12:35 PM   #6
jmlloar
jmlloar's Avatar
I have everything I need for the factory deluxe heater except the sheetmetal piece that bolts to the cab and the control cables.
My original cab had the deluxe heater that was rusted beyond repair and I must have not saved the flange that screws to the cab for it.
Old 11-16-2024, 01:43 PM   #7
dsraven
I bet that part could be fabled up easily enough. There is a rubber seal that goes between I think but that looks like a section of tire inner tube, possibly a wheel barrow or hand dolly size tire tube.
Old 11-16-2024, 01:52 PM   #8
mr48chev
mr48chev's Avatar
You have to know what it should look like to be able to fab something though. Maybe someone on here who has taken a non working heater like that out to put AC in still has all the pieces in the shed and is willing to offer them up.
My ongoing truck projects:
Old 11-16-2024, 01:56 PM   #9
jmlloar
jmlloar's Avatar
getting a used one would be great.
As far as fabbing one up its really not much more than a sheetmetal piece of angle folded to create a box.
Old 11-16-2024, 11:39 PM   #10
leegreen
Interesting to see the difference between 48-55.5 deluxe heater and 55.5-59 deluxe heater. The newer one blows through the heater core, the older one sucks through the core.
I reworked my rotted out with mouse pee '53 deluxe heater to put a jeep core and 12V fan into it. The core is both larger and finer fins than original, and it can take modern pressures. But the heat output is only OK, not the roast your wet jeans until they burn when you move I had expected. The core is hot, the box is hot, but it radiates more heat than the fan blows.
leegreen is offline   Reply With Quote
Old 11-16-2024, 11:49 PM   #11
dsraven
LG, can the fan source enough air and also is/are the outlet(s) large enough to allow the fan to discharge fully without restriction?
The heater in my boat called and a new core was not available. I sourced a new core from a common vehicle with inlet/outlets the correct sizes and configuration and then built a new heater around that. I used some of the old heater parts, fan etc, and it works fine again. Just saying if you can't find an original heater then make your own or modify a commonly sized and readily available universal unit for your purpose.
