helper air bags
Do you think they would cause a rear wheel hop at some speeds ??
Re: helper air bags
changing suspension geometry can change how the torque loads of the axle interact with spring / control arms. So lifting your ride height up might change axle hop.
the some speeds part : wheel/ axle hop is usually only going to happen when the suspension is loading up with torque, then releasing. Like when you are loosing traction on acceleration. If you have a vibration at certain speeds, it may be something other than wheel hop. Knowing what kind of rear suspension you are talking about might be helpful. But given the nature of this forum.....if your leaf spring suspension RWD truck has wheel hop when the tires are spinning the helper bags are probably not a big contributor. Look at stiffer springs (add back the overloads?) or add some axle twist control device, slapper bars, torque arm, caltracks |
Re: helper air bags
It's a 1989 gmc dually , leaf spring shock setup , does it in the 40-50 mile an hour area .
All rims balanced and front end alignment done , this could be helpful it still bounces when I let off the gas !! |
Re: helper air bags
check driveshaft, ujoints and center bearing, then springs, shackles and bushings
did you change anything before it started? |
Re: helper air bags
It was like that when I bought it
Re: helper air bags
Air pressure in the bags?
Re: helper air bags
![]() Join Date: Dec 1999
Re: helper air bags
Is the truck loaded? no need to run more than 10-20 psi in bags when not in use. That is from my experience. At the low pressure unloaded the bags provide a dampening effect on the leafs, taking away the jitters on the highway.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
Re: helper air bags
Richard I was thinking that and just let the air out of the bags yesterday but now I have to wait till next spring to see the difference , it's stored for the winter
Thanks all for the sugestions I wll get back on the outcome next spring |
Re: helper air bags
Definitely too high of air psi for a helper bag.
I never needed more than 30-40 on mine. My dually w/a 4-bar + sleeve bag swap (no leaf's) usually needs mid 50's when loaded down.
