Old 11-25-2024, 06:01 PM   #1
desert-rat
Location: 3,018 feet above the SoCal/Mojave Desert region.
4l60e or non 'e' best transmission for rebuilt 350?
I have a rebuilt 350 with a 4 bbl in my '72 C10. Currently has a turbo 400. Not the best highway transmission in my opinion. The truck is just a cruiser. No heavy hauling or racing. But do want an automatic transmission that'll handle WOT and has overdrive.
Will the 4l60e or 4l60 be best or what else do you recommend?
desert-rat is offline   Reply With Quote
Old 11-25-2024, 07:24 PM   #2
weq92f
weq92f's Avatar
Re: 4l60e or non 'e' best transmission for rebuilt 350?
It's not but with the right rear gear a nice compromise can be dialed up. The 400 is strong and reliable. If you put 3.08 in the rear, it would be much better on the highway around 70mph would be right at comfortable I'd say. Off the line, it'll do OK depending on your 350. Perfect for a cruiser.
If you want to have great performance off the line and low RPM highway speeds, you're gonna need that OD tranny or an OD unit hanging off the back of your 400. My buddy drives a 350/350/3.08 and keeps up with me all the way up to just over 80 fairly comfortably. Over 70 or so for short bursts only...it's a cruiser. My 700r4 w/3.73 in the rear is a very fun combo with my setup (Torquey 396). It will hammer good from a stop and cruise comfortably at 90 all day long.
For the money and effort I'd try the rear gear first. Maybe source a rear end with that gear and swap it for a test.
-Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 11-26-2024, 12:30 AM   #3
Accelo
Accelo's Avatar
The newer the transmission the lower 1st gear.
Everything being equal acceleration in first will be improved.
I always recommend a 1987 to 1992 4L60E as one also gets a 30% reduction in cruising RPM.
A much quieter cab is an additional benefit.
It will handle the 350’s HP with ease.
Accelo is offline   Reply With Quote
Old 11-26-2024, 02:53 AM   #4
Bob B.
A 4L60E is a 4L60, also known as a 'Turbo 700' (700R4), with electronic controls. Gear ratios are the same. A 4L60E will need a transmission control module and various sensors to shift properly, but aftermarket kits are available. The 4L60E also uses an electronic speedometer. The 4L60E came out in 1993. The Turbo 700/4L60 use a vacuum modulator and a kickdown cable to control shifting, so it's easier and less expensive to install in an older vehicle. The 700/4L60 also uses a mechanical speedometer, so that's no issue.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 11-26-2024, 08:28 AM   #5
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: 4l60e or non 'e' best transmission for rebuilt 350?
I believe that the 1982-92 700R4 only uses a TV cable for it's shifting purposes, and no vacuum inputs.
Old 11-26-2024, 09:36 AM   #6
cj847
cj847's Avatar
Assuming your budget has some kind of limit I would go 700R4.
With an E transmission there is a ton of expense. The transmission controller alone is over $700. Then I think you also have to have a throttle position sensor added etc. Wait until you do an LS swap and get all that for free.
I cannot quote the exact years but the early (1984-86?) 700R4 is said to be weak, but by now most have been rebuilt with later year internals. At some point the speedometer was changed to electronic but is easy to convert to mechanical with a <$100 kit. Make sure whoever installs it knows how to adjust the TV cable.
cj847 is offline   Reply With Quote
Old 11-26-2024, 09:57 AM   #7
Rickysnickers
Rickysnickers's Avatar
This is how my 700r4 is set up. Mine has no vacuum hook ups.
Old 11-26-2024, 11:22 AM   #8
dagnabbitt
dagnabbitt's Avatar
My 700R4 is a 1991, I think you want 87-92 for the best internals and highest number of splines, etc. It is certainly a difference maker if you drive the highway a lot like I do. I use a GPS Speedo.
Some people like the 200-4R as well. It depends upon your budget. if you are going for new - or rebuilt with better than new parts - then they are both great transmissions.
There's nothing tougher than a TH400, though. If you are generally happy with your truck and just want lower rpms, then before you swap transmissions and rear diffs you might check out Gear Vendors for about the same money.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 11-26-2024, 02:14 PM   #9
Bob B.
You are right, confused it with the TH350.
Old 11-26-2024, 05:49 PM   #10
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
My truck with the original 350/350 had 3:73's from factory out back. In 2019 I had a newly rebuilt 700R4 installed and was great upgrade. In 2023 a properly built small block 400 was installed in the truck. Nothing exotic just wanted a reliable ressponsive truck. If you dont want to race the truck and want a reliable driver I think a 700R$ with 3:73's out back with your 350 engine is the way to go.
1992 K1500 GMC Suburban
" In the end, we only regret the chances we didnt take "
" Time is the only currency we spend without knowing the balance, use it wisely ." ..
Old 11-26-2024, 07:34 PM   #11
pjmoreland
pjmoreland's Avatar
The early stock 700R4 configuration used a vacuum-controlled relay to lock/unlock the torque converter clutch based on throttle demand/manifold vacuum level.
pjmoreland is offline   Reply With Quote
Old 11-27-2024, 08:40 PM   #12
tim_mc
tim_mc's Avatar
Yep - I had my '92 700R4 built with a hydraulic lock-up kit that didn't require an electric solenoid. Here's a Transgo kit for reference:
https://transgo.com/product-details/...aulic-lock-up/
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column.
tim_mc is offline   Reply With Quote
Old 11-27-2024, 11:03 PM   #13
weq92f
weq92f's Avatar
My 700 is 1988 vintage. It's electronic lockup control is too rigid as installed. I would welcome a vacuum (or lack of) switch to unlock the thing under heavy throttle input. As it is, if I want that functionality, I've got to add a vacuum switch and some logic to make it happen...or lightly hold the brake switch with the pedal while I hammer the throttle!!!
So rather than that, I just live with the fact that when it shifts to 4th, it will lock and stay locked until I hit the brakes, shift to 3rd or hammer the throttle hard...and wait a half second.
Still a blast to drive...
-Kevin
Old 11-27-2024, 11:22 PM   #14
Accelo
Accelo's Avatar
Some owners install the 4L60 without connecting the Lock-Up. It will function fine, but you will not get the last 200-RPM reduction.
The later model 4L60E's can not easily be converted back to an analog speedometer. (They have 6 bolts holding the tail shaft versus the earlier ones with just 4 bolts).
The 4 bolt, tail shafts, can have the earlier analog tail shaft installed in place of the electronic ones.
All this is dealt with when using the factory computer and the 4L60E. They can include PWM lockup of the converter or just the (on-off). You can also set the shift speed electronically. They will also increase line pressure with a trailer or even if the computer high throttle application. It's like having a shift kit and then reverting when you no longer want to play. In some cases, they also will retain your speed going downhill by applying the converter clutch as required. They come highly recommended if you are running an LS motor. They just work!
