Old 11-26-2024, 02:36 PM   #1
straight6chevyguy
straight6chevyguy's Avatar
Question Sm465 hard to shift into low gear is this normal?
Hello all I have two squarebody trucks with the sm465 transmission
Both have trouble shifting into low gear. Sometimes I have to shift in and out of other gears or in most cases shift to neutral and pop the clutch quickly and at the right timing slide it into low. This is with the engine running and truck sitting stationary.
Is this normal for a sm465? Or do both my transmissions have a problem?
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1978 chevy c20 350 4speed
1998 chevy c1500 4.3L 5speed
2002 Chevy s10 4.3L auto 4x4
Plus a Mercury & some Fords... To many projects!
straight6chevyguy is online now   Reply With Quote
Old 11-26-2024, 03:25 PM   #2
geezer#99
geezer#99's Avatar
Re: Sm465 hard to shift into low gear is this normal?
Totally normal.
Low gear isn’t synchronized.
Old 11-26-2024, 05:02 PM   #3
straight6chevyguy
Ok... with the truck sitting still/parked?
I Understand while the vehicle is moving but never had this situation with my 65 Chevy (sm420?) at least not regularly maybe every once in a while but not every time I come to a stop.
And Ive messed with a 3 on the tree before and never had this either and it's 1st gear wasn't synchronized.
Old 11-27-2024, 09:41 AM   #4
Keith Seymore
Keith Seymore's Avatar
When you say "low" - do you mean the creeper gear, or normal 1st gear?
Because you really don't need to go into creeper gear at every stop.
It's more for pulling stumps.
Normal 1st gear is more appropriate for daily driving.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 11-27-2024, 02:21 PM   #5
straight6chevyguy
K
Yeah I'm talking about the creeper/granny gear.
And yes I'm aware that you normally drive these as a three speed around town.
Which I normally do. Though the other day I was towing a 5th wheel camper trailer with my 78 c20 and it was much happier taking of in low.
My original post was not really a complaint but rather just a question if this sort of thing was normal on these transmissions.
Old 11-27-2024, 02:31 PM   #6
straight6chevyguy
I had just initially thought that something was wrong with my transmission on my 76 C10 then I got a 78 c20 and it did the same thing so I started wondering if it was just normal or not.
If this is just the nature of the beasts then that's fine I can live with it. I found it odd because
Again I have messed with the older 4 speed in my 65 and even the 4 speed in my brother's 75 Ford highboy and there not at all this bad to shift into low gear.
Old 11-28-2024, 02:08 AM   #7
AcampoDave
AcampoDave's Avatar
Does it crunch when you try to engage it? Im wondering if youre getting enough throw on the clutch. Also maybe it was my imagination on my own truck but it seemed smoother when i changed my oil to "Driven" brand GL4 oil from Summit. I've had a few ""graany" gear trannies and I've alway been to engage them easily into low at a complete stop when the clutch was A-OK.
AcampoDave is offline   Reply With Quote
Old 11-28-2024, 09:50 AM   #8
Keith Seymore
Yes - totally normal and design intent.
K
1979-1986
1986 - 2019
Old 11-28-2024, 02:17 PM   #9
bnorth
Mine does the same. Tough to get into low gear especially if truck is not running. I usually put it in low when I park and it is especially tricky if the truck is shutoff.
1970 C10 l/b 292/4spd
Build: http://67-72chevytrucks.com/vboard/s...d.php?t=811062
bnorth is offline   Reply With Quote
