#426 |
Re: 1972 Medium Blue Highlander Blazer Resto
Enjoyed going back through this. Took a buncha notes. Thanks for the time you took to post all of this. I'd love to see more out and about pictures. Happy Holidays!
#427 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Thanks for the good words! I'll do better at posting some out-and-about pics. While garaged over the winter I need to remove the HEI and replace the pickup coil, which I believe is causing problems w warm starts. Have a Merry Christmas and Happy New Year all.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland
#428 |
![]() Join Date: May 2011
Say Pete,what might you have used for cushion on tailgate to hatch stop top of gate.Followed your restore missed it.Way cool work..Thanks for any reply.Paul..Double sided tape?
#429 |
Carpe manana
Great question. I had to think about this. If I recall, we used a non-hardening bedding compound along the seam of the tailgate strip. I'll take a peek and if I have anything else to add will let you know. Thanks for the good words. I've been battling the HEI and replacing the pickup coil is on my short list of to do's ahead of spring.
#430 |
Thanks for reply Pete.Did use double side 3m tape, worked good.Hoping to have top back soon,back at painters to do touchup.
#431 |
Carpe manana
You bet. I suspect that will work just fine. Good luck with remainder of the build.
#432 |
Carpe manana
Tempted to restore the original points distributor and ditch the HEI. 2B3 = 1972 (2) February (B) 3rd (3)
#433 |
![]() Join Date: Oct 2013
Do it!
1970 K20 Z62 https://67-72chevytrucks.com/vboard/...56#post9334756 1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
#434 |
Carpe manana
Yep. I'm doing it. May build an HEI too. Will post back as things develop.
Here's the shop I have in mind, owner seems like a nice and extremely knowledgeable guy: https://www.advanceddistributors.com/
#435 |
Subscribed!!!
Im about to start a K5 build soon.. lots of great info on here.
1966 C10 "Mary" 1967 C10 Custom "Ole Blue" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1979 C10 Silverado "The BIG TEN" C10 Club Texas -HMIC |
#436 |
Carpe manana
Welcome aboard and thanks for the good words. The build continues. Recently, I replaced the HEI with the original points distributor, which I sent for a rebuild and curve. The HEI left me temporarily stranded a few times and rather than disassemble it and replace the pickup coil I decided to can it.
Engine runs and idles better than ever but I’ve yet to do a long drive. Since I used a harness designed for use with an HEI that has no resistance built in the external coil I added has internal resistance. This coil has a slightly larger diameter than an OE example but fit in the OE bracket. The new plug wires are from Lectric Limited are US made and are precut for a 72 4wd application.
#437 |
Carpe manana
I’ve been able to get some seat time with the rebuilt distributor. This thing has never run better. Easier starts, just purrs at idle, and there’s great throttle response. Super pleased I did the swap. Fresh oil and a new coat of wax - ready for the summer.
#438 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Nice, looking good too.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
#439 |
Damn that girl is PHOTOGENIC.
Glad the distributor rebuild panned out so well. Following your lead per usual.
#440 |
![]() ![]() Join Date: Jul 2003
My 1972 Cheyenne responded the same. The MSD didn't cut the mustard. The rebuilt correct points distributor for the win!
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Frame off restored 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 51k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 71k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
#441 |
Carpe manana
Thanks for the good words guys. It's as if the Blazer was pouting about the lack of its original distributor. Sort of like that Brady Bunch episode where they took the idol from Hawaii and bad luck followed
The K20 gets along just fine with the HEI or so it seems.
#442 |
To make it clear, I am a fan of HEI systems. My mid-70's Pontiacs have had zero issues with them, especially after a recurve and maintenance to include replacing the pick up coil.
In these '67-'72 trucks, especially K series, I do not like them. The engine sits close to the firewall, and the larger diameter of the HEI distributor is not favorable. Also, the stock centrifugal/vacuum advance timing calibrations are for smog era low CR and wussy cams. Of course, these are easily addressed. As with the points system, quality old stock parts are crucial. Most of the new parts available today are of much lower quality than OEM Delco Remy.
#443 | |
I was able to locate a pair of the chromed diecast Yankee brand license plate frames for my 1970. Goes well with the correct 1970 USA-1 plate. Thanks for the idea.
#444 |
Carpe manana
Nice! Glad you found those. It's a shame that WI mandates a state front plate. I'd like to have the "Building a Better Way..." plate mounted again.
#445 |
Thank you sir. I've learned a lot from you. I'm proud of you
MY Facebook ( saad_alhajri ) on Instagram
#446 |
Carpe manana
Likewise Saad - thank you sir!
#447 |
Beautiful rig! You had mentioned way earlier in the thread you were running factory style shoulder harnesses out of a truck, I' m curious where you mounted the shoulder belt to and if you have pictures? Thanks!
#448 |
Carpe manana
Thanks for the good words! The belts bolt to the top at the "B" pillar into existing threads much as the pickups do. I'll take some photos and post back asap.
#449 |
Carpe manana
Example photos of where the male end of the belt attaches at the pillar and how I store the female end at the console with OE GM buckle “clips”
#450 |
Thanks for the pictures! I never noticed the tops had the provisions for the shoulder belts but that is very cool to know.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
