Old 12-10-2024, 09:42 PM   #26
weq92f
weq92f's Avatar
Re: Brakes - am I expecting too much
Originally Posted by my67c20 View Post
Technically, the front brakes should not lock up or you would loose that ability to steer.
...<snip>...
If the braking system is functioning (in these old trucks with disc brakes) as designed, it should be possible to completely stop the front wheels from turning at any time while driving. Yes, locking the brakes up would cause loss of steering, just as it does on ice and snow. When you see a person sliding on snow with all 4 wheels stopped (locked brakes), you see a person/vehicle completely out of control. In that case, the solution is to not stop the wheels from turning but rather, keep them right at the edge of loss of traction and stopping turning so that the slowing down of the vehicle is happening at the absolute fastest rate possible while maintaining the ability to steer. Pump the pedal if that's all you can do. On ice and snow, that rate isn't very good.
However when threshold braking a non ABS equipped vehicle on a dry road surface (such as described above), the rate of slow down that can be achieved with judicious application and moderation of the brake pedal to keep the tires right at the edge of loss of traction is exceptional. It takes skill. Skill that drivers today mostly do not possess due to ABS and the ease the tech brings to safety in braking. Just STOMP as hard as you can on the pedal with ABS and you'll stop as fast as the computer can do the modulation of the pressure to keep the tires right at the edge of their traction ability (given conditions).
There is no mechanical save your @ss from sliding directly into the thing in front of you in these old trucks. You must skillfully prevent the slide and maneuver to safety!
-Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 12-16-2024, 11:27 AM   #27
A1971Blazer
A1971Blazer's Avatar
I've recognized that it may be a bit more expensive, but while rebuilding the brakes on my '67 C10, I installed disc brakes only on the front and used a hydro-boost unit.
The braking performance is exceptional, and yes, it can easily lock up all four wheels; however, the braking efficiency and control make this a non-issue.
The brakes have a solid feel and minimal foot pressure is needed to bring it to a stop.
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
