12-16-2024, 03:00 AM | #26 |
Re: My C-30 w/Holmes wrecker adventure
Thanks guys for the views and nice words!
Steven, if you can weld with oxy-acetylene then you should have no trouble doing arc welding. In fact TIG welding is just like oxy-acetylene only the torch is electric instead of gas. All you need is to get some practice time. Have you considered taking a class? I would think that Simi Valley would have something to offer like community college or night school.
Best wishes to ya値l. Sincerely, Jim "To invent you need a good imagination and a pile of junk" - Thomas Edison "I've always wanted to get a job as a procrastinator but I keep putting off going out to find one so I guess I'll never realize my life's dream. Frustrating!" - Me Last edited by jhe.1973; 12-16-2024 at 04:08 PM. |
12-16-2024, 04:25 AM | #27 |
Hi Everyone,
November 21st I thought I was ready to drive the wrecker and use it to clear a few things from the backyard. I had let it run on fast idle for around an hour to try to use up the stale gas in the tank. When I shut it off I noticed the fuel pump was leaking from the crimped on bowl. I got a new pump from a fast food auto parts store in town and put it on the following day. It started just fine and then started stumbling severely as if too rich. I thought the float(s) might be sticking. When I got out to look (hood was already up) gas was pouring out of the top of the carb and all down its sides and was on fire. There wasn't any wiring or hoses etc. to burn where the flames were and I put it out with the with the ice tea I had handy. I returned the pump figuring I got one for a TBI application. I had been considering going to an electric pump so I wouldn't have to prime the carb after it had been sitting for awhile and figured now is the time. Here's the pump block off plate that I made: Here it is installed: This truck came with an auxiliary tank that wasn't hooked up under the bed right behind the cab. So, I installed a selector valve for dual fuel tanks at this time also: All the holes were already there so it was a piece of cake! It's gotten really late so I'll try to post more tomorrow morning about how I hooked up the tank behind the seat. I spent my day doing that today and have more photos to post.
Best wishes to ya値l. Sincerely, Jim "To invent you need a good imagination and a pile of junk" - Thomas Edison "I've always wanted to get a job as a procrastinator but I keep putting off going out to find one so I guess I'll never realize my life's dream. Frustrating!" - Me Last edited by jhe.1973; 12-18-2024 at 10:48 PM. |
12-18-2024, 02:59 PM | #28 |
Hi Everyone,
Here is a shot of the auxiliary tank’s spout that I will be hooking up eventually: The tank is held up by 2-14 inch long 1/2 inch diameter carriage bolts. Towards the upper right corner of this photo you can see where the diamond plate deck has cracked from the load of the tank. I will be repairing that before I get to actually hooking the tank up. The first thing I decided to do was to remove the OEM fuel line that went through the floor and bend the lower portion to point towards the driver's side where the selector valve is located: Because I wanted a rigid line in the cab, I cut off the end for the neoprene hose and installed an inverted flare coupling for a steel line extension. The plastic cap is from the local hardware store and fits the old hole great: The challenge now was to have my new line follow the floor as closely as possible to reduce the chance of damage later on. Because this would involve at least 3 bends I needed to place them in the correct orientation to the coupling and to the original line. Soooo, I made this and cut the vee groove that will allow me to use it with small automotive brake lines up to 5/16 fuel lines: By clamping the tool to the new line, parallel to the floor, I could remove the line and visually line up the bender in the shop in the same plane as the tool. In the foreground the line is marked w/a felt tip pen where the bends are to be. This allowed me to have it go through a rather small hole protected by a plastic grommet for electrical wires: It should be noted that it didn't come out perfectly on the first trial but needed a very small amount of tweaking to get it as shown in the final view. More to follow ........................
Best wishes to ya値l. Sincerely, Jim "To invent you need a good imagination and a pile of junk" - Thomas Edison "I've always wanted to get a job as a procrastinator but I keep putting off going out to find one so I guess I'll never realize my life's dream. Frustrating!" - Me Last edited by jhe.1973; 12-20-2024 at 01:51 AM. |
12-18-2024, 03:18 PM | #29 | ||
"I ain't nobody, dork."
Such a badass truck, and I'm diggin' your story too!
Gary
12-18-2024, 03:47 PM | #30 |
Thanks GASoline71,
Taking and editing photos, writing the descriptions and posting it all takes more time than I would like. However, I am glad to do it all when I see that the thread is being viewed. Getting comments like yours (and the others) is frosting on the cake!
Best wishes to ya値l. Sincerely, Jim "To invent you need a good imagination and a pile of junk" - Thomas Edison "I've always wanted to get a job as a procrastinator but I keep putting off going out to find one so I guess I'll never realize my life's dream. Frustrating!" - Me |
12-18-2024, 04:15 PM | #31 |
Sooo,
Following along with my fuel line saga, I pinched an insulated clip under a tank clamp as shown: This, combined with the small floor hole, made the entire line very rigid, reducing the chance of damage from anything knocking around the cab. Once it was clamped above the floor I started to bend it by hand underneath to get the orientation right and finished the bend in the shop. Here is how it looks all hooked up to the selector valve: The fuel pump has arrived along with a pressure regulator and gauge. I'll be making a rubber mounting system for the pump and it's filter today. Hopefully, I can install it all pretty soon ..... but we all know how that goes ...... something about life getting in the way ......
12-18-2024, 11:24 PM | #32 |
Hi Everyone,
Because I got a late start today I didn't expect to get much done on the truck. I thought this fuel pump mounting plate w/rubber isolators might be all: Daylight was fading but I figured I'd just go under and look around for a mounting spot. I wanted a spot that wasn't too rusty and to my surprise, just two holes to drill and finished. The inboard stud even picks up the reinforcing channel for the seat bolts ..... YAY! Here's how it looks from on top: Looking rearward to view the inboard stud for the rubber mount: The fuel pressure regulator and gauge came today but I don't know if I will be able to get back to the fuel system right away. I measured the roof sheet metal temperature late this afternoon and it was 69 degrees. It's supposed to be even warmer tomorrow and I may try to get the roof sealed. It won't be pretty but if I can keep it from leaking through another winter it will be worth the effort.
12-20-2024, 02:58 AM | #33 |
Hi Everyone,
Little bit of progress today cuz I got an even later start than yesterday. AAARRGGHHH!! There, I'm much better now. Assembled the fuel pressure regulator and gauge: After struggling to get what looks like a simple line from selector valve to the pump/filter here it is now: Looking towards the rear: I'll get the clamps on the neoprene connecting hose tomorrow. It was quite dark by this time and I was getting c..c..cold....
