12-19-2024, 10:14 PM | #1 |
Electrical
Still having electrical issues with my '71. My dash lights weren't working as well as brake lights. I replaced the headlight switch and that fixed the dash light problem....for a few minutes. Don't work again. Replaced the turn signal switch and the brake lights work. Not sure what to do about dash lights. Any suggestions???
12-19-2024, 10:23 PM | #2 |
Re: Electrical
Check all grounds, and make sure the fuse isn't blown. The instrument lamps circuit are run through a rheostat in the headlight switch. It is possible it is defective.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
12-20-2024, 04:20 PM | #3 |
Re: Electrical
Do the lights in the heater panel light? If not then it's likely a problem in the 12v positive power supply to the lights instead of all of the grounds being bad. Do what 1970cstblazer said and check the fuse and the switch.
I recently had the brake lights quit working on the Burban. The fuse looked good but a test light showed it wasn't making a good connection in the holder. I removed the fuse, tested it and found it was good and the caps were tight so I reinstalled the fuse I had brake lights again. Good luck and let us know what you found.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
12-20-2024, 09:45 PM | #4 |
Re: Electrical
The dash lights' power originates with the tail lights. If the tail light fuse blows, the dash lights will also fail.. Check the tail light fuse.
12-24-2024, 05:38 PM | #5 |
Re: Electrical
I'm thrown off by the dash lights working for a very short time after installing a new headlight switch. I've checked and rechecked all the plug connections and still no dash lights. I visually checked all the fuses and they looked Guess I'll pull out the multimeter and check continuity....
12-24-2024, 06:23 PM | #6 | |
The Older Generation
Re: Electrical
Does the dome light work if you rotate the headlight switch knob to the on position?
12-25-2024, 08:13 PM | #7 |
Re: Electrical
This photo may help. (Thanks to Palf70Step for the photo! ). I've had problems in the past with the wiper on the dimmer portion of the switch not making good contact with the coils on the rheostat. (Green circle) Check that the rivet that holds the terminal just above the green circle is tight and it makes conductivity with the terminal and the wiper.
Broken parts on the shaft in the area in the yellow circle can cause the rheostat to lose contact with the wiper.
12-25-2024, 08:59 PM | #8 |
Re: Electrical
pontiacvince
Does your wiring harness still have this ground clip? Is the clip and surface clean?
12-27-2024, 04:24 PM | #9 |
Re: Electrical
12-27-2024, 04:26 PM | #10 | |
Re: Electrical
