Old 12-21-2024, 11:58 AM   #426
clay68c10
clay68c10's Avatar
Re: ClusterTruck; because that’s what it is
I needed to mount my LS fuse box, and wanted it to look factory-ish. I thought about closing in the bottom fully, but decided keeping it open fit the vibe better and gives some access.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 12-22-2024, 10:47 AM   #427
clay68c10
clay68c10's Avatar
Now for some AC parts. My harness came from the deliverance dude and looked pretty decent. Seems it had spent some time outside tho. The relay had no continuity when I tested it.
Time for a relay upgrade since these just work and I have lots of them.
13 Tahoe LTZ
Old 12-22-2024, 11:06 AM   #428
clay68c10
clay68c10's Avatar
I wanted to add a heater core shut off valve but wanted to maintain the LS bypass. Some research led me to this setup. It fits well and should work.
The hard line and some T’s are from the 4wd actuator circuit off a 2013ish 5.4 Expedition. Plenty of those in the junkyard.
I used a little heat from a lighter to get the bends in the vacuum line. It’s teed into the same circuit that actuates the cowl flaps for recirc.
13 Tahoe LTZ
