Old 12-30-2024, 04:28 PM   #1
LDO
LDO's Avatar
Radiator id help
I am hoping someone can tell me what I have and what I need to make it right.
1985 Suburban, 350/700R4.
I believe I have a big block radiator in it.
The dimensions are 29" wide 21" tall and 2 1/4 deep.
The shroud is a two piece and fits horrible.
PO made some crappy straps to hold all this stuff together and I can't stand it.
It looks like I might be missing a separate cover panel as well.
LMC has a few different parts, wondering if some will work.
I want a shroud that fits properly and installed correctly with the correct brackets etc.
Thank you in advance.
LDO is offline   Reply With Quote
Old 12-30-2024, 07:59 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Radiator id help
there are supposed to be some rubber pieces on top where the factory top clamps to the radiator and the top half of the shroud is missing some clips and bolts not to mention it appears cracked
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-31-2024, 12:47 PM   #3
Dead Parrot
No clue on what is proper for your suburban but what is in my 75 C10 is a 3 row radiator that is about 34" wide, 19 high and 2.75 thick.
It is a replacement but was obtained when several old school radiator shops still existed and you could get parts that matched OEM. 350/TH350 w/AC.
Sounds like a PO made something fit that wasn't OEM sized.
Dead Parrot is offline   Reply With Quote
Old 01-01-2025, 01:52 PM   #4
Pontiac1976
Pontiac1976's Avatar
TIP: to tell what core you have. Remove the rad cap look in the hole if you can see the tube count how many if there all open that will be the count of flows, if any are blocked off don't count that one. i.e.: 3 open tubes it's 3core. If it has 4 tubes but only 3 are open 3 core.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
