Old 01-04-2025, 02:21 AM   #26
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: Gas shelf life
Originally Posted by KQQL IT View Post
Why because Ethanol eats rubber parts ?
My quadrahet get used daily ish and still needs an accelerator pump every 6 months
Before Ethanol. On my '68 C/10's 292 L6, It was rigged with a Holley 4160 R8007 -- 390 CFM 4Bbl/ Offy Intake/ and Clifford Long Tube headers. I remember how every backfire cost me $5.95 for a 8.5Hg new power valve, and I had to get some member of the Holley tribe to guide me thru the mysteries of carburation. You couldn't just slap a new part in, you had to retune.I found I'm a klutz around swiss watches and found a less complicated system with the Carter AFB. I found them idiotproof.
There was a quadrajet on my '71 GMC Jimmy. When I bought it PO had replaced the stolen OEM 350 with a Goodwrench 305. Unfamuliar with the breed, I turned in the Original as a core to Checker Auto, got a generic repop and got limited results.
At one point I had a Holley 780 CFM DoublePumper on that SBC. I also tried 100 Octane Race Gas. I didn't get to experiment with it much because, coincidently, the engine Sucked Valves on both #6 and #7 cylinders. And I had to sideline the Rig.
When I rerigged that Jimmy, I got a Mr. Goodwrench 350/Weiand intake, Heddmam Hedders, Carter AFB, 600 CFM 9635S/ HEI.
It's been running OK for about 26 years. I can't recall the total mileage.
You must have a more aggressive alcohol in the pump gas mix in Cal. I've noticed more Fuel Pump failures due to agressive fuel solvents in AZ, but not so much carb distress.
Old 01-04-2025, 02:39 AM   #27
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Gas shelf life
Fuel is terrible here.
Old 01-04-2025, 07:19 PM   #28
Rust_never_sleeps
Rust_never_sleeps's Avatar
Re: Gas shelf life
Looks like a fair bit of moisture in there
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is offline   Reply With Quote
Old 01-05-2025, 02:11 AM   #29
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Gas shelf life
Central California good fuel, typically shell 91
The ethonal pulls moisture like a sponge
Old 01-05-2025, 03:43 AM   #30
Rust_never_sleeps
Re: Gas shelf life
The water in the fuel comes from condensate on the inside of the tank, not absorption out of the air, so keeping the tank full makes a big difference. I only recently learned this.
Old 01-05-2025, 12:27 PM   #31
72c20customcamper
72c20customcamper's Avatar
Re: Gas shelf life
Well technically the moisture condensates from the air inside the tank it’s not coming from the gas itself. Vented systems suck and expel atmosphere with temp changes . But yes it’s best to keep it full so less atmosphere is exchanged but there always will be some exchange
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 01-05-2025, 02:42 PM   #32
Rust_never_sleeps
Re: Gas shelf life
I found the article back, and as they say, water doesn't transfer directly from air to fuel, it needs to condense on a surface.
Keeping it full works because less surface of the tank is exposed, it has nothing to do with how much damp air is inside
https://www.boatus.com/expert-advice...yths-clarified
Also a good bit about how ethanol dissolves gunk from the tank that would otherwise presumably just fall into the sludge and stay out of the way
Old 01-05-2025, 05:02 PM   #33
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Gas shelf life
Something had changed dramatically from 1999 when It sat til 2005 when I decided to redo it again.
It ran and drove with a new battery and water bottle worth of gas poured into the carb vent.
Now it doesn't sit over a month without something failing in the fuel system.
Old 01-05-2025, 06:37 PM   #34
72c20customcamper
Re: Gas shelf life
Standard logic would dictate that with less headspace you have less air but you will still get some condensation . If you topped it right to fill neck you would get very little . Just like when I bottle condition beer to much headspace flat beer to little and you get a geyser.
If you stored gas in a complete vacuum and fill the container half full you wouldn’t get any condensation.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 01-05-2025, 06:58 PM   #35
howzzzit
howzzzit's Avatar
Re: Gas shelf life
I don't drive my truck too often, but every time I add gas I also add Berrymans B12. This is a piece from their factory.
B-12 (#0116, #0112 and #1112) disperses water, causing it to be broken into smaller globules that can be carried out of the tank and burned through the combustion system or trapped in the fuel filter. The small amount of water that is carried through to combustion actually aids in the removal of carbon build ups in the combustion area. If larger amounts of water are present such that the filter plugs readily, remove the filter and spray B-12 through from the outlet side to flush out contaminants. Replace the filter and continue to repeat the process until the water is removed and then replace the used filter with a new one.
howzzzit is offline   Reply With Quote
Old 01-05-2025, 06:59 PM   #36
slikside
slikside's Avatar
Re: Gas shelf life
You can just about eliminate the issue if you get carb parts designed for use with ethanol fuels. Cliffshighperformance.com is one such source for quadrajets. I’m sure there are others as well…
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
slikside is offline   Reply With Quote
Old 01-05-2025, 07:02 PM   #37
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Gas shelf life
They all seem to fail.
My holley gets all the neoprene methanol safe parts.
Fails about half as fast
Old 01-05-2025, 07:23 PM   #38
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Re: Gas shelf life
Cliff's accelerator pump diaphragms come with a lifetime warranty, says at his site.
~Steven
Simi Valley, CA
Old 01-06-2025, 02:09 AM   #39
Luke87gt
Luke87gt's Avatar
Re: Gas shelf life
Great post.
Question: My '69 has sat for years. What is the easiest way to drain the fuel?
Would it be where it transitions from hardline to rubber, right under the stock tank?
If I break that junction, it'll drain close to empty as that line is below the tank?
1969 C10 Shortbed
Luke87gt is offline   Reply With Quote
Old 01-06-2025, 07:27 AM   #40
Re: Gas shelf life
I have a cheap little electric fuel pump with some battery clips I use to pump my stuff out into cans.
Old 01-06-2025, 09:34 AM   #41
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Gas shelf life
Good to know.
Have to get one for old blue.
Now that it's cooled off its acting like it wants another one
Old 01-06-2025, 01:01 PM   #42
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Gas shelf life
Originally Posted by Luke87gt View Post
Great post.
Pop cap off. It'll smell to high heaven if it's gone bad
Then make a drain fush plan or consider replacing the tank.
Old 01-06-2025, 04:26 PM   #43
Rust_never_sleeps
Re: Gas shelf life
Great post.
It'll be siphoning through the sending unit(assuming there's fuel all the way through the line).
No more or less effective than dropping in a siphon hose, depending on how cooperative the gunk in the bottom is, and a bit less convenient, but if you're going to pull that hose to swap it anyway...
EDIT: and the vent hose
Old 01-06-2025, 05:46 PM   #44
Rust_never_sleeps
Re: Gas shelf life
...not uncommon to unmount the tank and slosh marbles or similar around in there to dislodge the accumulated sludge out of the bottom
Old 01-07-2025, 02:25 AM   #45
'68OrangeSunshine
Re: Gas shelf life
I have something like that. I have a Holley Blue racing pump.
I use it to transfer gas from jerry cans to the gas tank. But I'v also used it to transfer gas from one truck to the other, or to de-gas a fuel tank [to jerry cans] so I could work on the Fuel Level Sender.
Old 01-07-2025, 02:38 AM   #46
'68OrangeSunshine
Re: Gas shelf life
Using my Holley Blue fuel pump
