Old 01-16-2025, 07:59 PM   #1
camaro_red
camaro_red's Avatar
56” rear spring swap on my 70GMC
Looking to swap to an all spring lift in my 70 GMC.. have Skyjacker CR26S 6” lift rear springs that are 56” not the 52 the truck came with.. do I need to replace the rear hanger ?.. if anyone has done so your input would be appreciated
____
______//__{\_____
,/_(O)__/____/_(O)_/
camaro_red is offline   Reply With Quote
Old 01-16-2025, 10:06 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: 56” rear spring swap on my 70GMC
I am going to move this to the '67 -'72 truck board. I think you will get more replies on it there....
Leon
Old 01-16-2025, 10:44 PM   #3
Richard
You should move the front hanger 2" forward and the rear shackle hanger 2" back. That will keep the axle in the stock position. That is assuming the pin is centered in the pack.
Edit- just want to make sure the new springs are specified for a 56" long spring application. If you are just measuring them, the 6" lift pack for a 52" application will be longer than your stock 52" springs. 4" longer would be a lot, but wanted to ask.
Edit again- looked up your springs as should have done previously. Says "Designed to fit models with 56 in. leaf springs." So my original recommendation stands.
Richard
