Old 01-16-2025, 09:21 PM   #1
tucsonjwt
female connector for fuse box
I need to connect a circuit for my gear vendor to a circuit that has power with the ignition on. I found an open slot but it looks like it needs a female connector end. The slot in the fuse box is "L' shaped. Where would I find a factory style female end connector/pigtail? It is hard to see but it looks like it has only one brass spade terminal in the fuse box cavity, and I have only seen female end pigtails which don't look like they would fit into the L shaped slot cavity. Thanks.
tucsonjwt is offline   Reply With Quote
Old 01-17-2025, 01:22 AM   #2
franken
Re: female connector for fuse box
Sounds like a packard 56 connector.
franken is online now   Reply With Quote
Old 01-17-2025, 08:38 AM   #3
tucsonjwt
The Packard 56 connector appears to be a single male spade connector. I am attaching a pic of the fuse box for a square body. I have circled in red the type of slot I am trying to connect to. It appears to be an L shaped slot with only one spade terminal, so I think I need a female connector with two prongs to attach to the single spade connector (like the female side of a spade terminal connector, only with an outer insulator in an "L" shape to match the slot in the fuse box. I have a connector and pigtail in this type of slot in my fuse box already, so it seems that they existed at one time and I hope they are still available. Thanks.
Old 01-17-2025, 12:39 PM   #4
Bloodhound
These are what you need. Expensive if you just need one, but it's what fits correctly.
https://www.summitracing.com/parts/a...RuZstOj-i1CsAm
Bloodhound is offline   Reply With Quote
Old 01-17-2025, 03:35 PM   #5
tucsonjwt
Thanks. That looks like a build your own connector type of device. On the same page is: Pico GM Fuse Block Taps 0951PT which looks similar. Would this work? With this connector, is it just another male brass spade that rubs up against the male brass spade in the cavity? I was thinking I would need a female spade for the male spade in the fuse box.
Old 01-18-2025, 12:40 AM   #6
HOGDADDY
HOGDADDY's Avatar
That will work also because I have used them.
HOGDADDY is offline   Reply With Quote
Old 01-18-2025, 11:36 PM   #7
kwmech
Every time I visit the wrecking yard I look for those connectors and cut the pigtail as long as I can
Old 01-20-2025, 12:08 PM   #8
tucsonjwt
Thanks for the tip about the junkyard. Unfortunately, there are no square bodies left in the junkyards around here because an old rust free desert square body is worth a lot more than scrap value. If one does get to a junkyard they will sell it as a whole project truck and get good money for it.
It seems that there are two styles of connectors - one for a battery (constant power) connection which is black as shown above, and one for a accessory (ignition on) connection. I want the accessory one so I ordered one off Amazon. These connectors are pricey and not readily available. It takes over a week to get one, but only $8.00 with free shipping with Amazon Prime.
PICO makes the connectors - 0952PT for the accessory pigtail (white) and 0951PT for the battery pigtail (black.) Quality Distributing LLC sells these items but they charge for shipping if you buy them directly from them (about $8 for shipping to where I am,) which doubles the price to $16 unless you buy more than one to reduce the cost of shipping per unit.
It still seems odd to me to have two male spade terminals - I would intuitively think you would have a female to male connector.
Old 01-27-2025, 10:47 PM   #9
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
Remember that it isn't just squarebodies in the junkyard with those connectors. Any 80s GM and maybe into the 90s could have them. Still might not be that common, but more places to look... Also, they used to be on the wiring rack at NAPA. I haven't looked lately but that's another place.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '87 C10, '87 R30, 2 '89 R3500 Flatbeds
ElGracho is offline   Reply With Quote
