Old 01-21-2025, 12:17 AM   #101
dsraven
Re: First truck build '49 3100
curious how much higher the filler is than the tank. I was a gas jockey for a bit during high scholl and remember a 72 chevy sport truck that came in with a set up just like that. it filled but it also took a long time and burped back a lot. have you tried filling it yet?
not dissing your build at all, looks great and good workmanship by the pics. just saying it's better to find out sooner than later so if there is a problem you can fix it before it gets painted etc
Old 01-21-2025, 12:49 PM   #102
e015475
e015475's Avatar
Maybe 6-8" - no issues filling the tank
.......it's better to find out sooner than later so if there is a problem you can fix it before it gets painted etc
That ship has sailed........
e015475 is offline   Reply With Quote
Old 01-22-2025, 11:13 AM   #103
dsraven
Yup. Looks more like a sleek race boat than a ship. Lol. Nice job.
Old 02-11-2025, 11:54 AM   #104
Brads49
I got the engine all done and ready, good recommendation of replacing the main seals while it's out! I ended up moving the engine and trans forward 2" to clear the distributor on the firewall although I kind of wish I would have measured more before cutting into the firewall for valve cover clearance but oh well live and learn I guess. I ran fuel lines last weekend but my only concern is where I went over top of the crossmember that the front of the bed sits on, I think I'm going to have to put a couple of bends in the line to snake it under that; I don't remember if the bed actually sits on top of it all the way across.....
I finally quit procrastinating and cut the notches in the front frame rails to make clearance for the steering so now I need to finish welding them all in and clean up the edges and paint it. Then we're on to the brake system to finish up the chassis.
Brads49 is offline   Reply With Quote
Old 02-12-2025, 06:37 PM   #105
Brads49
What are yall using for the master cylinder / brake booster setup for 4 wheel disk brakes? I see most online are listed as disk/drum or drum/drum setups. I'm planning on keeping it under the floor unless that's just not an option with having 4-week disks. Thanks in advance....
Old 02-13-2025, 12:32 AM   #106
dsraven
If going under floor I recommend a Hydro boost from a newer donor vehicle and possibly one that comes with 4 wheel discs. The Hydro boost is a smaller system, gives good power brake boost compared to the smaller dual diaphragm vac units. If you could find a hydro boost from a silverado with your engine configuration so the brackets for the p/s pump fit or an astro van if using a sbc or something like that with disc/disc, and get the whole set up down to the power steering pump etc. That would be optimal. There are several of those shown in builds on here. Check ogres build, for one. A quick search would show more.
Old 02-13-2025, 09:45 AM   #107
dsraven
there are a couple of hydroboost builds here if you search it from the search window above and click the circle from web to 67-72chevytrucks.com
ogre has pics and an explanation in his build
kim57 also has one in his build with pics and a home made bracket mounted further back on the frame for access
Old 02-13-2025, 07:06 PM   #108
nvrdone
Hey Brad: Just thought I would send you some info on my brake system on my '49.
First off, it's a 327 / m21 / no power steering with front & rear stock drum brakes.
I decided to upgrade to power brakes and here's what I used: Booster kit from POL, p/n bb2-t4755. M/c from Napa, p/n m2153. Pedal mounting kit from No Limit p/n pbc-47.
The m/c is disc /disc since I plan on adding front & rear discs in the future. I have 10# check valves in both front & rear lines to make the m/c work with the drum brakes. I also have an adjustable proportioning valve in the rear line to adjust brake pressure.
It stops really well - better than it did stock - but not like my Jeep srt8.
I thought about a hydro boost but that would require power steering. Also, I was told that an under floor booster would not work with the m21 trans. But it has plenty of clearance.
Hope this info gives you somthing to think about.
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's
Bought in 1973 for $235.00. Had it longer than my wife & Kids!!
nvrdone is offline   Reply With Quote
Old 02-14-2025, 12:23 PM   #109
Brads49
Thanks for the input guys! I am going with no power steering so the hydro boost set up wouldn't work for my build. I will likely piece something together like nvrdone did if I can't find a kit that lists disk/disk application. Since we have a snow day here in Oregon I'm going to finish all the suspension stuff this weekend so that I can start ordering the brake system so I can hopefully keep up the momentum on this project finally.
Old 02-14-2025, 01:39 PM   #110
dsraven
Look for a donor car or truck that has disc/disc. Check the bore size as well. With manual brakes too large of a bore will take more pedal effort.
There was a build here that used a modified stock pedal system but the shaft for the lever went through the frame to the outside of the frame. The outer end of the shaft had the lever for the pushrod attached and the booster was mounted under the floor outside the frame. That made room for stuff between the frame rails. A search on the site may come up with some pics though.
Old 02-14-2025, 01:46 PM   #111
dsraven
here is a thread on sizing brakes, using disc disc, what factors to consider, etc
https://67-72chevytrucks.com/vboard/...d.php?t=806263
Old 02-14-2025, 01:52 PM   #112
dsraven
found the thread with the booster under the floor and on the outside of the frame rail
post 5
other good info in there too
https://67-72chevytrucks.com/vboard/....php?p=7531548
Old 02-14-2025, 02:52 PM   #113
dsraven
I see you are using a ford 8.8 rear axle with disc brakes.do you know the specs for the rotor diameter your IFS uses up front? rear discs on the ford explorer were just a hair over 11 inch I think. it will become a balancing act because no donor truck has the same weight distribution as your project but, with that said, you can do yourself a favor by starting with a set up that tries to match what you need for brakes front and rear.a front rotor would generally be the same or larger diameter than the rear rotor and probably have more friction surface area, possibly a larger pad friction surface area and possibly a larger caliper piston size or maybe a dual piston caliper. depending on what your front spindles were sized for you may be able to have the same size rotors up front as the rear axle donor had (ford exploerer?) and so may be able to use the same size master cylinder as the exploerer and the same size of caliper piston, to keep things a little better balanced to start with. then possibly an adjustable prop valve to dial in exactly what you need for brake bias once the truck is running and driving on the roadways.
personally i am not a big fan of the small diameter dual diaphragm vacuum brake booster but if you are going with an under floor installation you are generally restricted for booster diameter so thats what would fit. I really like the idea of mounting the booster outside the frame as an access panel could be built into the step area of the cab for easy servicing. if you look at the aftermarket brake booster set ups you will likely find the booster is from a donor vehicle, like an S10 or something. if you are a fabricator you could easily make the brackets and linkage required to make your own frame mounted booster. it is easier to buy a set up though, for sure.
if you have a modified engine you may need a vacuum pump and reservoir in order to have sufficient vacuum for trouble free booster operation. these are available as belt driven units, like newer LS engines come with, or electric units available in the aftermarket.
just some thoughts.
Old 02-24-2025, 12:45 PM   #114
Brads49
I ended up ordering a pedal / booster / MC set up from Speedway Motors. I'm told everything will work with 4-wheel disks. The best thing about using the Ford 8.8 is that the hoses / hard line / mounting brackets are all readily available so I got all of that replaced with new so now hopefully this coming weekend I'll get the rest of the lines bent and installed so I can move on to the next phase.
Old 02-25-2025, 10:05 AM   #115
Rickysnickers
Rickysnickers's Avatar
Speaking from my own experience, I'd change out that fixed proportioning valve to an adjustable one, something like Wilwood makes. You are most likely mixing and matching parts, and having the adjustable unit will help dial in the bias, from front to back, for your braking.
https://www.summitracing.com/parts/w...caAscBEALw_wcB
Old 03-03-2025, 11:36 AM   #116
Brads49
I got my brake lines plumbed this weekend. I don't know what the front calipers are from so I need to call Southern Rods and see if they know so that I can get the proper rubber lines to finish them off. I started painting the firewall of the truck and put the cab back on to make sure it lines up with the mounting locations and doesn't hit the distributor. I'm glad I moved the engine and trans forward 2".... it gave me about 1/4" between the distributor and the firewall. I coated the new floor panel I built with truck bedliner (cause I had it) and got it installed so now I'm trying to get everything done with the cab so that I can paint the inside and start getting insulation and wiring installed.
Old 06-12-2025, 12:44 PM   #117
spr85gmc
spr85gmc's Avatar
Glad I found this thread. Great build with a lot of helpful information.
spr85gmc is offline   Reply With Quote
Old 10-28-2025, 10:55 AM   #118
Brads49
Well the weather is changing here in the PNW so it's time to get back on the truck. I test fit the inner fenders and radiator support to make sure I don't have any conflicts with brake lines and such. Then pulled it apart (for the 50th time) to paint the inner fenders. I sprayed truck bedliner on the wheel side, and I'll spray the engine bay side with semi flat black to match the firewall.
I am trying a homemade spray booth out of a temp car canopy set up in my shop. I'll have a fan on the end with a filter to clear the "room" out the door. Definitely not professional BUT it should contain overspray and be easier than covering everything else in my shop to keep clean. I'm hoping to have some stuff painted this weekend so we'll see how well it all works.
1949 Chevy truck build
https://67-72chevytrucks.com/vboard/...d.php?t=778470
Old 12-17-2025, 11:50 AM   #119
Brads49
When I bought the truck, the previous owner had planned on doing an original restoration and had the hood and doors primed. So since I'm wanting to keep the patina that it has, I needed to match the green as best as possible. I took one of the vent doors in so that they had something to match against and they mixed up the paint. I used wet coffee grounds to create the "rust" spots where it might look like rock chips or something on the hood. I painted the hood and doors and then sanded them down. The color isn't exact BUT I don't have 76 years to wait for it to naturally oxidize and I think once I put some matte clear on it, it might be closer. I just got done painting the inside of the doors so now I can take the front end apart again and pull the cab and get the inside of the cab painted and then actually start re-assembly of the cab and get some glass installed etc.....
I'm a plumber by trade and body / paint work kind of scares me so this phase has been on my radar for a long time but I've been procrastinating on actually doing it.
Old 12-17-2025, 12:10 PM   #120
dsraven
It sure would look nice all painted.....
Just my opinion. I drove rusty and sad for a long time cuz paint was well beyond budget
Mine get paint now. Haha
Looking good tho. Don't let the "never painted before" thing get you. Just wear the right safety stuff and start by laying primer down like you would if you were painting. Have lots of light from different angles and keep watching how it's laying down as you spray. Orange peel on a first coat is gonna stay orange peel so add another pass after letting it sit for a sec to see if it flattens out. Having the shop temp figured out for the correct reducer helps so the reducer can do its job properly and help stop runs that may not have happened or orange peel cuz the paint just didn't have time to properly melt into the underlying coat. Short intervals between coats can cause bubbles cuz the first cost is still off gassing but the second coat sealed in the gasses.
Anyway, do a few YouTube apprenticeship videos and try it out. Maybe you're awesome at paint.
Old 12-17-2025, 12:50 PM   #121
Tempest67
Tempest67's Avatar
I mixed Rustoleum colors together to get the closest match I could for the rear roll pan. Then misted flat black and red primer til I thought it looked like the tail gate.
then, in a few spots, dragged the red oxide primer to try to make rust 'runs'
If you don't like it, just sand it off and try again,
Have fun with it
Tempest67 is offline   Reply With Quote
Old 12-17-2025, 01:00 PM   #122
dsraven
Maybe develop a "patina wrap". It would make you rich for the look PLUS the protection factor.
Old 12-17-2025, 01:06 PM   #123
Brads49
I've seen a couple of cars at local shows that have patina wraps done....... it's really obvious that it's printed and just doesn't look right IMO. Getting a car wrapped around here is still thousands of dollars these days. I just wanted to keep the truck as original as I could with the factory paint on most of it since it was purchased new and has spent it's 76 year life in this area. I have a shiny painted Nova when I want to drive it but I just wanted something different this time.
Old 12-17-2025, 01:07 PM   #124
Brads49
Have fun with it
That rollpan looks great! This is what I've been telling myself on the exterior, the whole point is to not have a "show winning" paint job so worst case, I sand it all off and do it again.
Old 01-05-2026, 12:58 PM   #125
Brads49
I've been trying to keep up forward momentum on the truck. I got the inside of the cab painted and I'm working on installing some sound deadening mat while I wait on my glass to show up. The plan is to get the cab to a point where I can install in permanently on the frame and close it up. I'm going to bleed the brakes before putting the cab on while everything is easy to get to.
