01-24-2025, 11:14 PM | #1 |
Senior Moment
Dakota Digital issues
I’ve had a Dakota Digital dash in my 70 for 10+ years. All of a sudden as I’m driving along the Tach, SpeedO, Fuel gauge and temp gauge will go to Zero then back AND it’s not always all the gauges but always the Tach and SpeedO
Volts and Oil Pressure are not affected. I am running an LS just FYI Has anybody else experienced this???
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
01-25-2025, 09:45 AM | #2 |
Re: Dakota Digital issues
Are you picking up the speedo from the OBD port or is it set-up separately using the VSS in the trans?
01-25-2025, 02:23 PM | #3 |
Senior Moment
OBD port
01-25-2025, 09:13 PM | #4 |
Have you contacted Dakota Digital about this? I've had good results from their support.
1970 GMC 2500 700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles. 350 SBC 300hp Weiand Supercharger FiTech 30004 EFI |
01-25-2025, 11:59 PM | #5 |
Senior Moment
Yes. They said to check connections. It’s worked perfectly for 10+ years. I guess a connection could come loose ??? Anyway I’ll pull the unit and check out the connections
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 Last edited by 1970 CST Short Wide; 01-26-2025 at 02:09 PM. |
