Old 01-26-2025, 03:37 PM   #1
adf5565
Rear engine oil leak question
Unfortunately after a had my ‘72 350 rebuilt by a friend it developed an oil leak at the rear of the engine. I believe it is the rear gasket of the oil pan, however I would like to confirm it’s not the rear main seal as well. Would the crankshaft be “wet” if the rear main was leaking? I haven’t noticed anything on the crank.
It’s probably hard to tell from an image but there is oil at the corner where the rtv ends. But I haven’t noticed any oil running down the back of pan either, it was originally running (a few drips after running the engine) down the front facing sheetmetal piece of the bell housing cover (sm465).
adf5565 is offline   Reply With Quote
Old 01-26-2025, 03:40 PM   #2
adf5565
Re: Rear engine oil leak question
I should also add that he struggled to find a rear/front gasket piece for the oil pan that fit right. Hence the sloppy look. There is another spot on the oil pan the leaks as well. So at the very least the oil pan is coming over to replace the gasket.
Old 01-26-2025, 03:48 PM   #3
adf5565
Another pic after running. Definitely leaking at the oil pan seal at least, oil can be seen at the rear pan lip.
Old 01-26-2025, 04:20 PM   #4
RustyPile
RustyPile's Avatar
That's a goopy mess.. Redo the installation and use the proper pan gasket set, and not so much gasket sealant....
RustyPile is offline   Reply With Quote
Old 01-26-2025, 10:01 PM   #5
HO455
HO455's Avatar
It is difficult to do with the engine in the truck but after removing and cleaning, dry fit the pan to the block and inspect it to see the pan fits flat and square.
If you not pulling the engine to reseal the pan, try test fitting your pan on a different block that's not installed to verify the fit.
Oil pans can take a lot of abuse and many new ones just don't fit correctly.
RIP Bob Parks.
Old 01-26-2025, 10:08 PM   #6
treveiger
treveiger's Avatar
Looking at the picture I would guess that's where it's leaking. I bought a reusable felpro one piece gasket that has no leaks for nearly 15 years.
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 01-26-2025, 11:01 PM   #7
Rust_never_sleeps
Rust_never_sleeps's Avatar
Those little blue clippy things that come with the Fel-Pro silicone gasket really help keep it from getting distortedf
1970 C10 Custom longbed 350/350
Code:
            __
     ______|__]\____
....|___(o)_____(o)_]
Rust_never_sleeps is offline   Reply With Quote
Old 01-27-2025, 11:38 AM   #8
Sheepdip
Sheepdip's Avatar
As HO55 said those pans have taken a lot of abuse over the years, a new thicker one can be had for less than a $100 and a stock shaped aluminum for $150 or so. That and a 1-piece gasket should solve the problem, unless it is the rear main leaking.
Sheepdip is offline   Reply With Quote
Old 01-27-2025, 12:48 PM   #9
adf5565
Thanks for the replies. I ordered a 1 piece gasket and will take a look at the oil pan and see if I need to order a new one. My plan is to replace it with the engine in the truck, I have the ability to lift the front of the engine a little if needed as well.
