Old 01-29-2025, 02:29 PM   #1
dooguy
help with tire size
I have a 72 k20 with 4" rough country spring lift. debating on installing 33" or 35" tires. I will be mounting them on 10" wide x 16" diameter wheels
motor is stock 350.
basically a road princess.
wondering what others thoughts are on this combo
thanks
dooguy is offline   Reply With Quote
Old 01-29-2025, 02:46 PM   #2
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: help with tire size
K20 will have a minimum 4.10:1 gear ratio, so the 33"-35" tire size will actually make the truck much easier to tolerate at highway speeds, and the 350 will have enough torque to move it adequately.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 01-29-2025, 02:52 PM   #3
dooguy
looking for some info on the 33" vs 35"
guy at tire shop was a little negative on 35's
checking to see if anyone had negative experience with the 35 vs 33
ie.. rubbing or ride things
Old 01-29-2025, 04:05 PM   #4
my04
my04's Avatar
My '68 has a 2" lift with 285/75-16's (equal to 33's), no rubbing at all. Drives great.
1966 Custom Camper -327, 3OTT
1968 Chevrolet K20 - 350, 4 speed
1972 K10 SWB - 400, 3OTT
2003 Corvette Z06 - LS6 350, 405HP
2004 Tahoe LT
2015 Silverado 2500HD - 6.0L V8
my04 is offline   Reply With Quote
Old 01-29-2025, 04:33 PM   #5
Mendo70C20
Mendo70C20's Avatar
I have a 70' K20 with a 4" lift and i'm running 35's. I have 4.10 gears and a Tremec 4050 5spd trans.
Mendo70C20 is offline   Reply With Quote
Old 01-29-2025, 07:21 PM   #6
dooguy
nice looking trucks
Old 01-29-2025, 08:40 PM   #7
57taskforce
All about them K’s
57taskforce's Avatar
1972 K20 around 5” lift in the rear and 4”+ a little in the front because of the dana 60 I swapped in, 315/75R16 (as similar as you will get with 16” wheels to 35’s) on 10” wheels. 350/SM465. Runs about 2600 RPM at 70 MPH. Doesn’t rub under normal driving conditions, and have only had it run once or twice off road fairly flexed out.
Tyler
