Old 03-18-2024, 03:07 PM   #551
LockDoc
The Older Generation
LockDoc's Avatar
Re: LockDoc's "Low Budget", "Low Maintenance" Project Thread
I re-tested the gauges again using Patrick's suggestion. I meant to post a close up of the labeled gauge yesterday but forgot to. (picture 1)
Picture 2 is the overall view of the connections.
Picture 3 is a close up of the connections with the extra, stock 90 OHM resistor added.
Picture 4 is the readout on an old gauge I have
Picture 5 is of the gauge in my good cluster.
Instructions are the same as before, just with the extra resistor added.....
Leon
Old 03-18-2024, 03:26 PM   #552
pjmoreland
pjmoreland's Avatar
Looks good!
pjmoreland is offline   Reply With Quote
Old 03-18-2024, 09:40 PM   #553
Getter-Done
Getter-Done's Avatar
Great Information.
The early bird gets the worm,
85 Chevy K-20
Old 03-18-2024, 10:27 PM   #554
LockDoc
LockDoc's Avatar
Originally Posted by pjmoreland View Post
Looks good!
Originally Posted by Getter-Done View Post
Great Information.
Thanks guys.
Leon
Old 03-20-2024, 08:21 PM   #555
LockDoc
LockDoc's Avatar
Installed the headlight relays today. Pretty straight forward if you follow the instructions on the board. You can buy the kits from almost every truck parts supplier or put your own kit together from junk yard parts.
Below are the diagrams. First one is Chevy, second one is GMC
Leon
Old 05-16-2024, 09:58 PM   #556
LockDoc
LockDoc's Avatar
Picked up a 4.10 gear for the Dually HO72, to replace the 5.14. It should drop the RPM and help the mileage some. I need to get a new pinion seal for it.
Leon
Old 05-16-2024, 10:43 PM   #557
3757chevy
3757chevy's Avatar
Nice , good info. Thanks
Very nice , should help a bunch.
'67 Stepside (bought 1997-sold 2021-partially bought back 2024) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 05-17-2024, 12:08 PM   #558
LockDoc
LockDoc's Avatar
Thanks. I will know in a few days....
Leon
Old 05-17-2024, 01:01 PM   #559
Getter-Done
The 4:10 will be a nice addition.
I am guessing 2200 RPM at 70MPH.
85 Chevy K-20
Old 05-17-2024, 04:07 PM   #560
LockDoc
LockDoc's Avatar
Thanks, I hope so.
Leon
Old 06-01-2024, 11:30 PM   #561
LockDoc
LockDoc's Avatar
I've been working on the replacement 4.10 center section for the rear end. I not only had to replace the pinion seal but I also had to install a pinion seal repair sleeve. I could tell when I looked at it that the seal was going to need replaced. The yoke had a pretty good groove in it when I disassembled it. I filled it with JB Weld and installed the repair sleeve while the epoxy was still wet.
I only had to pull the axles out far enough to clear the center section when I removed it..
I had to figure out how to get the center section up in the air far enough to get the transmission jack under it so I put a piece of steel pipe across two of the frame cross members and put a rachet strap over the pipe and around the bottom of the center section. I just tightened the rachet strap up until the center section was high enough to get the jack under it. I cut the heads off of 2 bolts and screwed them into the housing to use as guide pins to locate the center section. (you can see one of them in the 8th picture) When I got it high enough I just slid it onto the pins and put the bolts in. Before I slid it all the way back I put some "Right Stuff" sealant on the gasket.
The rest of the pictures are the gasket, and specs on the gasket, seal, and repair sleeve.
Leon
Old 06-01-2024, 11:32 PM   #562
LockDoc
LockDoc's Avatar
Pictures.
Leon
Old 06-01-2024, 11:34 PM   #563
LockDoc
LockDoc's Avatar
More pictures.
The pinion seal and pinion repair sleeve were ordered from Rock Auto.
Leon
Old 06-02-2024, 10:22 AM   #564
Getter-Done
Nice work on the Rachet strap lifter device.
30 years ago, you would have done that differently?
85 Chevy K-20
Old 06-02-2024, 11:59 PM   #565
LockDoc
LockDoc's Avatar
You got that right. Now I have to use my brain more and my muscles (that I don't have) less....
I haven't checked my mileage yet but it dropped my RPM to about 2450 RPM @ 60 mph.
Leon
Old 06-11-2024, 08:55 PM   #566
67-72C10
67-72C10's Avatar
The best way I found to put on or take off the hood springs is while they are bolted on the truck hook a fan belt on the end of the spring right on the tip of the coil. While standing in front of the truck pull and lift it off the hinge bracket.
To install just hook the rear on hinge then with the fan belt on the tip of the spring and pull and hook it on the hinge.
67-72C10 is offline   Reply With Quote
Old 06-11-2024, 10:43 PM   #567
LockDoc
LockDoc's Avatar
Sounds like that would work good because of the extra leverage you would have. Thanks for the tip!
Leon
Old 06-15-2024, 06:30 PM   #568
3757chevy
3757chevy's Avatar
I use a ratchet strap with the same concept as a fan belt.
MIKE
Old 06-15-2024, 11:29 PM   #569
LockDoc
LockDoc's Avatar
That would work good too. Thanks!
Leon
Old 09-29-2024, 10:06 PM   #570
LockDoc
LockDoc's Avatar
I finally got a couple of things finished up on the Dually Project that I have been working on for a couple of months off and on.
One of them was the cruise control, and the other was the temperature gauge that wasn't reading correctly.
The problem with the cruise was the switch was bad. I replaced the switch and it now works great!
The temperature sender on the 8.1 is a 3 wire sender and the Green wire was for the instrument panel gauge. (first picture) The stock '71 temperature gauge was reading really low, just above the cold line, when HPTuners said that the actual temperature was 195º. (second picture) I solved that problem by adding a 150 OHM Resistor - Colors: Brown-Green-Brown-Gold, between the Negative side of the gauge and the ground post at the bottom. (third Picture) That made the gauge read just above the center line @ 195º (fourth picture)
Here is a good resistor color calculator:
https://resistorcolorcodecalc.com/
I was really glad to get these two things finished up.
Leon
Old 01-28-2025, 09:27 PM   #571
LockDoc
LockDoc's Avatar
I've been trying to get the steering box and Hydroboost dialed in for the last week or so. The steering was pretty "twitchy" because of the higher pressure produced by the hydroboost unit. I purchased this pressure reducing kit off of Ebay and installed it in the power steering pump where the high pressure line enters the back of the pump. I used 3 of the shims. That should bring the pressure down to about 900 - 1000 psi.
https://www.ebay.com/itm/291813791972
It did help the twitchy feeling but the steering box also needed adjustment because it was a little sloppy. Yesterday and today I worked on that problem using the instructions from this YouTube video.
https://www.youtube.com/watch?v=VRO1ne-SkZo
I looked at quite a few videos but this one was the easiest to follow, for me. I need to take it out for a drive tomorrow morning and see how it feels. Hopefully there will be an improvement in the handling experience....
Leon
Old 01-29-2025, 02:42 PM   #572
LockDoc
LockDoc's Avatar
Drove the truck about 20 miles round trip to go get some lunch. The adjustment made a big difference and makes it a lot more enjoyable to drive. I'm a happy camper....
Leon
Old 01-30-2025, 12:32 PM   #573
CG
BlahBlahBlah
That really is a good vid on how to set up a steering box. Saved the vid in my favorites
Old 01-30-2025, 02:11 PM   #574
LockDoc
LockDoc's Avatar
Yes, the guy is a little like I would be if I tried to make a video. A lot of Umm's and Aww's, but it is still easy to follow.....
Leon
Old 02-02-2025, 05:23 PM   #575
54blackhornet
54blackhornet's Avatar
Leon you are amazing ! Thanks for sharing your knowledge.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
