MPFI Spider
I have a '96 k1500 with a 5.7 R engine.
Spider assembly went bad,so ,try ing to save $$,I bought a set online,...yeah,...bad move. So after 6 months they went bad....what brand do y'all recommend ? Is Sorensen ok ?
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect ! I'm busier than a one-legged cat,in a sandbox! Veteran..and proud ! I can't fix what ain't broke....you want I should break it? |
Re: MPFI Spider
On fuel system parts I try to stay with Bosch, Delphi, AC Delco, Echlin..........any of the known brands that give good warranty.
All about them K’s
![]() Join Date: Jun 2014
Re: MPFI Spider
Agreed Delphi or ac delco are my preferences. Get the updated injector assembly that converts it to multi point injection and ditches the single injector setup. I’ve had really good results using them in the past.
https://www.rockauto.com/en/catalog/...+injector,6224 For example… the part in question on that list is the new GM assembly that has the injectors down on the bottom of the “spider legs” rather than one central injector and the poppet valves at the bottom of the legs that the original style injector had.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s Last edited by 57taskforce; 01-30-2025 at 04:22 PM. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
