Old 01-21-2025, 01:04 PM   #51
Tip70
Tip70's Avatar
Re: 1970 Jiffy Mount Tire C10 build
Originally Posted by Stickman View Post
Looks awesome
Thanks!
1970 C/10 SWB
build thread:
https://67-72chevytrucks.com/vboard/...d.php?t=847860
IG- Tip70
https://www.etsy.com/shop/Tip70Designs
Tip70 is offline   Reply With Quote
Old 01-27-2025, 10:21 AM   #52
loudchevy
loudchevy's Avatar
Originally Posted by Tip70 View Post
made these decals for the bed scars
I love these decals! Looking forward to seeing the interior door panels finished.
Scott
1970 C10 Restomod|454/700R4|LWB-->SWB Build Thread
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 01-31-2025, 04:36 PM   #53
Tip70
Tip70's Avatar
I thought the decals would be a funny thing to put on
1970 C/10 SWB
build thread:
IG- Tip70
Old 01-31-2025, 04:40 PM   #54
Tip70
Tip70's Avatar
Here are some progress pics of the door panels. They are going together good, just need to figure out some spacing on the door and panel with the handles and also how to mount the pull strap, because the bracket is a bit bulky than I was hoping.
1970 C/10 SWB
build thread:
IG- Tip70
Old 01-31-2025, 05:03 PM   #55
loudchevy
loudchevy's Avatar
Those door panels are looking sweet
Scott
2003 Tahoe Stock
Old 01-31-2025, 06:05 PM   #56
Tip70
Tip70's Avatar
thanks man! they are coming together
1970 C/10 SWB
build thread:
IG- Tip70
Old 01-31-2025, 07:24 PM   #57
Shifty One
Shifty One's Avatar
I like those panels!
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Old 01-31-2025, 07:32 PM   #58
Tip70
Tip70's Avatar
thanks something a little different
1970 C/10 SWB
build thread:
IG- Tip70
Old 02-11-2025, 08:04 PM   #59
Tip70
Tip70's Avatar
Started mocking up the raised bed floor. I was able to pick up some wheel hubs and some wood. Earlier last year I got a good deal on some metal bed strips as well. All Im missing is some square tubing to start building my frame.
In the future, I will C notch the frame. So I left the original hubs in and have the new ones in place. This will give the look Im looking for and also be ready later. You'll have to stick around and see if this turns out how I planning
1970 C/10 SWB
build thread:
IG- Tip70
Old 02-25-2025, 07:08 PM   #60
Tip70
Tip70's Avatar
I was able to figure out a good mounting spot for the handle pull and have the panels installed. Now seeing the shot from the inside, I'm thinking I may have to make some kick panels
1970 C/10 SWB
build thread:
IG- Tip70
Old 06-04-2025, 12:57 PM   #61
Tip70
Tip70's Avatar
Painted up the tire wells to match the truck, also I did a bit of body work on the back tailgate. not perfect but getting there. learning as I go
1970 C/10 SWB
build thread:
IG- Tip70
Old 06-04-2025, 01:01 PM   #62
Tip70
Tip70's Avatar
touched up my door logos by hand painting them this time. also gave a drop shadow. I'm liking how they turned out, compared to before.
Also made a chrome badge for my air tank to give it a more finished look.
1970 C/10 SWB
build thread:
IG- Tip70
Old 06-20-2025, 01:05 PM   #63
Tip70
Tip70's Avatar
Last couple of weeks I have been putting in some time fabbing up my raised floor frame. Got the inner part done, Now just need to add the outer framing and make up the door that will show off the air ride equipment.
1970 C/10 SWB
build thread:
IG- Tip70
Old 06-20-2025, 01:23 PM   #64
Tip70
Tip70's Avatar
I took this old tool box I had laying around and painted/weathered it. Also Printed up some stickers of 70s era companies. I thought it would be cool to have a bed prop that could have been in the back of the tire shops work truck.
Ill have it bolted down so it cant get stolen. Also it will be a good place to lock things up when at the shows or just taking it out while doing some errands.
1970 C/10 SWB
build thread:
IG- Tip70
Old 06-27-2025, 01:17 PM   #65
Tip70
Tip70's Avatar
Worked on the hatch frame. When I was at my metal supplier, they had bowties for sale so I had to incorporate it into the project Still trying to figure out a hinge option. One that will not hang up on the 1 3/4" of thickness (1" of steal and 3/4 wood) If you have any ideas and pics, please share also ones that wont break the bank! Ive seen the ones that are $500+
1970 C/10 SWB
build thread:
IG- Tip70
Old 06-27-2025, 01:20 PM   #66
Tip70
Tip70's Avatar
Added some color to the bowtie. I plan on doing a black stain on the wood, so I think it will look good and pop with the green
1970 C/10 SWB
build thread:
IG- Tip70
Old 08-04-2025, 01:20 PM   #67
Tip70
Tip70's Avatar
Got some more work done on the bed floor. I had to weld up almost every hole in the wear strips, since Im having a way different lay out with the trap door and all. After that I started cutting down the strips and working with the boards, getting them cut to size.
Im liking that Im finally getting to see what the raised floor will look like.
Next will be to router out the boards to accept the wear strips. one step at a time!
1970 C/10 SWB
build thread:
IG- Tip70
Old 08-05-2025, 10:19 PM   #68
clay68c10
clay68c10's Avatar
Cool idea. That’s gonna be slick
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 09-02-2025, 03:33 PM   #69
Tip70
Tip70's Avatar
Some more progress on the bed. I have all the wood pieces router out and now will be going through the sanding/finishing process. Also was able to get some scissor hinges made up from a friend and installed with some gas struts.
1970 C/10 SWB
build thread:
IG- Tip70
Old 09-02-2025, 04:00 PM   #70
loudchevy
loudchevy's Avatar
Those are cool scissor hinges!
Scott
2003 Tahoe Stock
Old 09-02-2025, 05:11 PM   #71
Tip70
Tip70's Avatar
They turned out great These help get the door up and out to clear the wood and also hide underneath when closed.
they are modeled off of another hinge out there that cost $500. I didn't want to spend that and when you have illustrator and a friend with a laser CNC, can save some money
I wish it would open up a bit more but i think it still is a good angle to shows off the tank and compressors
1970 C/10 SWB
build thread:
IG- Tip70
Old 10-01-2025, 01:30 PM   #72
Tip70
Tip70's Avatar
Getting Closer! I have the wood pretty much sealed up. I wanted the wood to be black, but with the spar urethane giving it a warm feel, I'm not hating it
I still need to re-route the filler hose and some other odds and ends, then I can get it all bolted down.
1970 C/10 SWB
build thread:
IG- Tip70
Old 10-01-2025, 02:02 PM   #73
68 C10 Driver
I just found your thread today, fantastic workmanship! This will certainly be a truck that will turn heads at the car shows. Keep up the great work, I look forward to seeing what else you plan. BTW, I loved the headliner, great idea to use magnets to keep it attached!
68 C10 Driver is offline   Reply With Quote
Old 10-01-2025, 03:40 PM   #74
Tip70
Tip70's Avatar
Thank you! Its a fun line to walk, making it look good and not worry about everything being perfect
The magnets are holding up great! Hasn't fell down on my head yet Hopefully soon Ill have photos posted of the bed floor completed.
Not sure what will be next for the winter season. stay tuned!
1970 C/10 SWB
build thread:
IG- Tip70
Old 10-06-2025, 02:45 PM   #75
Tip70
Tip70's Avatar
Update on bed installation, Front Half....The Tool box is bolted down and will be more of a prop/mini storage.
1970 C/10 SWB
build thread:
IG- Tip70
