C60 Hump
I'm starting to do some research on putting my cab on a f350 dually frame. the truck currently has the no hump hump. Are the bolt patterns the same as on a high hump 3/4 ton?
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis 1964 GMC K10 383cu in/sm465/twin stick np205 1965 Chevy C60 1990 Chevy Bus 8.2l fuel pincher 8800 miles 1993 Ford F350 crewcab 7.3idi nonturbo ZF5 Transmission Running on WMO |
![]() ![]() Join Date: Jul 2003
C40-C60 floor hump:
![]() C10-C30 floor hump: ![]() By looking at these, it appears the bolt patterns are not compatible. I would check and see if 1973-91 C40-60 humps will work in the older trucks. The floor pans appear similar. 1976:
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Frame off restored 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 51k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 71k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
#3 | |
Re: C60 Hump
I converted my c10 to high hump out of a 3/4 ton. had to cut part of the floor out of the 3/4ton to do it. wonder if that may be the same deal
| Bookmarks |
| Thread Tools | |
| Display Modes | |
