Th400 slips above 50 mph
I have an 81 jeep CJ7 with a sbc 350, th400, and bw1339 transfer case. I had the transmission rebuilt about a year ago. I put around 3,500 miles on it and one cold morning it started slipping. It would slip only when traveling above 50 mph. I would let off the gas and it would catch and drive fine. It did this 4 or 5 times in a 35 mile trip. On the return trip it started slipping to the point that I had to drive below 20 mph to limp it to a safe place to park. I pulled the transmission and took it to a shop for a rebuild. The invoice shows that a master kit with friction, steel module, shift kit, modulator, solenoid, filter, and torque converter were installed.
After installing the newly rebuilt th400 and filling it with fluid, I ran the jeep on jack stands. Everything seemed good. It backed out of the garage fine and turned around in the driveway. When I took it for a test drive, I slowly accelerated and everything was good until I got to approximately 50 mph and the engine suddenly revved high. I let off the gas and made a u turn. The vehicle again accelerated fine but I only went up to about 35 mph to avoid any possible slipping. Back in the garage and on jack stands it seems to work fine. Pressure test while on jack stands with vacuum modulator unhooked P: 165 R: 260 N: 165 D: 160 2: 180 1: 180 Pressure test with vacuum modulator connected P: 100 R: 160 N: 100 D: 95 2: 180 1: 180 The modulator valve was also checked. It is not leaking and moved when vacuum was applied. The fluid is clean and does not smell burnt. I used Valvoline Dexron VI as instructed by the builder. Sorry for the long post. I wanted to provide as much information as I could. Any ideas, advice, or suggestions to assist with trouble shooting this would be greatly appreciated. The transmission is currently installed in the vehicle. |
Re: Th400 slips above 50 mph
Very rare to have problems with the bulletproof th400. So it has been rebuilt twice and still slips? I am not a trans expert but I would suspect something is wrong with the governor or the valve body. Maybe a valve is sticking in the valve body. It's definitely rare.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
I don't have a lot of experience with automatic transmissions. I was thinking a lack of pressure for 3rd gear but the pressure shows good on the gauge. I am thinking there is an issue that is not being addressed through a standard rebuild. Maybe a faulty part that is being reused so possibly the valvebody. I don't think anything has been done to the governor in the rebuilds.
Update for anyone that may come across this thread later with a similar issue:
After testing everything possible with the transmission and trying a old transmission it appears the problem may be somewhere else. The transfer case has 2 clutch cones in it which appear to be slipping. I have not been able to pull the transfer case apart to verify this yet. When the transfer case is "locked" there is no slipping. When it's unlocked in AWD the slipping occurs. The transfer case has a new chain, new seals, and new fluid but the clutch cones have not been changed. Last edited by DD38; 01-31-2025 at 04:13 PM. Reason: Additional information |
I guess that makes more sense. I have never even heard of that transfer case. It sounds like you are getting it sorted out.
I rebuilt a Blazer transmission for a guy and then got the dreaded call. His Wife was on the freeway on-ramp with a dead transmission.
Showed up ready to tow it home. Ended up putting the transfer case back into gear and all was right with the world. |
| Bookmarks |
| Tags |
| slip, th400, transmission |
| Thread Tools | |
| Display Modes | |
