Old 02-08-2025, 09:57 PM   #1
IT Cowboy
IT Cowboy's Avatar
Do these codes on the FW mean anything?
My truck has these numbers and codes written on the firewall. Do they mean anything or was this someone trying to mimic or reproduce the factory mfg codes used in mfg.
1972 C10 Custom Deluxe Highlander 402
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is offline   Reply With Quote
Old 02-08-2025, 10:40 PM   #2
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Re: Do these codes on the FW mean anything?
L47 is your engine- 400 CI
M49 is your trans- 400 THM, I'm sure
J70 is power brakes, which were an option on 1/2T trucks
CE10934, see the chart
These were aids for the people on the assembly line for picking the components.
~Steven
Simi Valley, CA
Old 02-09-2025, 01:57 AM   #3
57taskforce
All about them K’s
57taskforce's Avatar
Is your truck a St. Louis build? I’d bet it is. They were famous for tatting up the firewall with assembly/option codes.
Tyler
Old 02-09-2025, 08:06 AM   #4
1970cstblazer
1970cstblazer's Avatar
Wink Re: Do these codes on the FW mean anything?
My St. Louis built 1970 Blazer had all sorts of tats on it's firewall. I replicated these during the resto.
PT- ?
Z84 - CST trim package
KE10514 - 4WD V8 Blazer 104" WB
LS9 - 350 4 BBL V8
J70 - Power Brakes
M20 - 4 speed manual trans
Old 02-10-2025, 11:55 AM   #5
Keith Seymore
Keith Seymore's Avatar
Grease pencil markings:
http://67-72chevytrucks.com/vboard/s...light=sequence
http://67-72chevytrucks.com/vboard/s...light=graffiti
http://67-72chevytrucks.com/vboard/s...d.php?t=545345
http://67-72chevytrucks.com/vboard/s....php?p=6543084
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
