![]() Join Date: Sep 2007
Window crank handle repair....need advice
So I got a couple of nice 67 inside window crank handles a I'm the knobs are missing
Anyone know how to put a new or a good used knob in and where to get the knobs only so I could use these handles?. I did a search but I didn't find anythnng
1967custom |
Re: Window crank handle repair....need advice
You may have to go on the hunt for some good original factory handles at swap meets.
I don’t know if any vendor that just has the knobs. |
![]() Join Date: Jan 2012
Dorman makes a product, part number 76905 that appears to be pretty good copy of the stock knobs. It comes with the knob, a "rivet" and a washer. Should be available in yhe HELP section of your local auto parts store. I've never use them but may be worth a shot. Maybe someone else has used them and can chime in.
These are old pics but show what's included and the instructions. Obviously they've been making these for a while now. Last edited by cericd; 02-12-2025 at 11:20 PM. Reason: better images |
![]() Join Date: Apr 2016
I don't know if the knobs are one of the 67-one-year-only items. If they are like 68-72 then the knobs can be obtained from the car parts stores in clear and black. I believe I got mine at Napa. Here is a recent discussion. https://67-72chevytrucks.com/vboard/...d.php?t=856396
Yep, those look to be the same as the Dorman ones I was referring to. I posted pics of the old packaging because the Napa and Oreilly sites don't show the hardware for attaching the knob. Napa is even using the same exact images as the Oreilly site for the Dormans shown here. Any issues installing them? Do the feel like they'll hold up with regular use?
![]() ![]() Join Date: Jan 2005
![]() Join Date: Feb 2002
I have used the Dorman Repop knobs. They work OK, for a while, but can come loose.
The best method of setting the rivet in the knob is to put it in a vise and slowly compress the knob onto the rivet thru the handle. Whacking it on with a ball-peen hammer can lead to misalignment or mishaps. Over torqueing can cause the knob to be too stiff, and not roll freely. Dorman also used to sell the full handles, w/knob attached. Don't try them -- they suck, and can be too brittle, breaking off in your hand. Better a real GM handle to work with.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 02-13-2025 at 06:36 PM. |
a new complete handle is only $5-8 depending on where you get it.
https://classicparts.com/chevy-gmc/t...ith-black-knob |
#9 | |
These are '67 only cranks and handles. |
![]() ![]() Join Date: Jul 2003
https://www.ecklers.com/ca-corvette-...RoCitIQAvD_BwE
https://www.classicindustries.com/pr...RoCwF4QAvD_BwE
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Frame off restored 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 51k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 71k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
I have had a '67 K/10 Suburban and I remember the unique slimmer '67-only design. I have run the '68 style Door Handles and Window Cranks -- they fit the splines fine, as I recall. I don't remember if the round knobs were the same. Thought so. Not sure.
The later models are stouter, and won't break as easily. But not period correct.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
