Old 02-13-2025, 04:55 PM   #1
PbFut
Photo of steering box area needed.
After fire reassembly in progress. I changed over to a hydroboost and making the hose lines. Can someone shoot a picture or two of the steering box area? I can't recall how much room i have. This is my preferred layout. I can't remember if the radiator support or inner fender will interfere and too lazy today to assemble and disassemble
PbFut is offline   Reply With Quote
Old 02-13-2025, 05:21 PM   #2
PbFut
Re: Photo of steering box area needed.
never mind. It inner fender hits. Think I may dill access hole for pressure side. I need the hose on top side of inner fender anyway
Old 02-13-2025, 06:45 PM   #3
57taskforce
All about them K’s
57taskforce's Avatar
I think you will be fine. Here is the setup on my K20. I cut the o ring end off and removed the nut of the pressure line from an ‘09 silverado and added an inverted flare nut and re flared it. (Had a brand new line on the shelf from another project and decided to finally use it) As you can see the routing hugged the box nice but was not happy with the inner fender. I too did this upgrade with no font clip on the truck and just decided to trim the inner as needed when I was putting the rest of it back together.
Tyler
Old 02-13-2025, 07:08 PM   #4
PbFut
Yup
I just placed support and inner fender. Easier than posting the question. Needed a 1" hole. Fender has 8 holes I need to fill so what's one more. Surplus gomet finishes fairly well. Angle of steering box and fitting played well relative to fender. It touches but not under stress. I'll relative some when I weld the old holes.
Old 02-13-2025, 10:26 PM   #5
Classic Bowties
Always on the hunt...
^ ^ ^ Were a bit late with this info seeing that the above inner fenders have already been violated, but per your original thread topic maybe this info and pics will help someone searching in the future. We shared this post and pics in the below linked thread of another member that was working on a hydroboost conversion: We are no help on the aftermarket style AN fittings for the style of hose that you are wanting to run, but we did just happen to finish up a P/S conversion on a customers ride and have a few pics to share detailing the OE style hose fitting bends and tight inner fender to hose clearance issue at the p/s gear. Mel
https://67-72chevytrucks.com/vboard/....php?p=9183579.
***For any return/past customers & friends***
Before sending of any funds, please wait for a confirmed total and instructions for
sending as our payment account info has been changed as of Jan. 2023. Thanks...
Classic Bowties is offline   Reply With Quote
Old 02-14-2025, 03:05 PM   #6
PbFut
Classic, Those are stock OEM style lines and only the return is tappable for connection to Hydroboost. The pressure side for the steering box does not go to the pump when using Hydroboost. The pressure line in a Hydroboost set up goes from the pump to the Hydroboost. Then from the Hydoboost to the steering box. 3 Lines needed for hydroboost units. The lines pictured in my 1st post shows the path of the pressure lines. The waist line of the Hydoboost is not yet in place in the photo. The waist/return line goes from the waist port of the hydroboost and tees into the return line of the steering box. The OEM style pressure hose shown in Classic Bowties post is not really usable for hydoboost.
If one were good at bending and flaring, it would be possible to fabricate a 3/8 steel flair line from the steering box pressure port to the steering shaft access area and flair connect to a 6an flex hose to the Hydroboost if one needed to avoid modification to the inner fender. My inner fender is already drilled in other areas and rusted some so it was not an issue in my case.
Old 02-15-2025, 06:56 PM   #7
Classic Bowties
Classic, Those are stock OEM style lines and only the return is tappable for connection to Hydroboost. The pressure side for the steering box does not go to the pump when using Hydroboost. The pressure line in a Hydroboost set up goes from the pump to the Hydroboost. Then from the Hydoboost to the steering box. 3 Lines needed for hydroboost units. The lines pictured in my 1st post shows the path of the pressure lines. The waist line of the Hydoboost is not yet in place in the photo. The waist/return line goes from the waist port of the hydroboost and tees into the return line of the steering box. The OEM style pressure hose shown in Classic Bowties post is not really usable for hydoboost. If one were good at bending and flaring, it would be possible to fabricate a 3/8 steel flair line from the steering box pressure port to the steering shaft access area and flair connect to a 6an flex hose to the Hydroboost if one needed to avoid modification to the inner fender. My inner fender is already drilled in other areas and rusted some so it was not an issue in my case.
PbFut, I think that you must have only viewed the added pics without reading any part of my reply or added quote (part in bold) in above post #5, these hydro boost conversions have been being completed successfully for years now and am fully aware of the hose and fitting changeover issues that arise. Nowhere above did I state "Hey, just use these hoses and fittings to get the job done", my above post clearly says we are of no help on the fitting/hoses needed but here are some pics showing the OE style hose fitting bends and tight inner fender to hose clearance issue at the p/s gear, which again was the original request and title of this thread. Mel
Old 02-15-2025, 10:46 PM   #8
PbFut
Mel I failed reading compression on this one.
Your return line fitting and tube is usable by the way and makes connection for the hydroboost waste line a snap.
