3D printed radio delete plate
I recently inherited a 3d printer from a buddy who was getting poor results from it and got tired of messing with it. Took a bit to get it fixed up and decided what better thing to learn CAD and 3d printing with than some 67-72 parts.
I’m still pretty much garbage with CAD, but I’m new to it. Here is my result from copying a radio delete that was sitting on my workbench. I’ll post the STL file if anyone else on here has a 3d printer and wants it. Ignore the neon yellow color, it came with the printer and it’s what I have for now while I’m mostly just fiddling around with this. I’ll eventually buy some better colors when I get a little better at this.
67 Short Step - 454 & Muncie 4-speed |
#2 | |
![]() Join Date: Jun 2022
Re: 3D printed radio delete plate
Thin PLA prints can warp in the heat, so perhaps good to go 100% infill and make them 1/4" thick(I have no idea what the actual minimum would be) ...or just use PETG, which is harder to print pretty, but has better properties
1970 C10 Custom longbed 350/350 “Carburetors are forgiving, timing is not” — Thunderhead289 |
#3 | |
I do have a spool of ABS still in its package that I haven’t tried out yet. This PLA is old and not been kept in any kind of dry container so I’m sure it’s not ideal as-is. I’m just burning up all this wacky neon yellow getting used to printing. I kinda like being able to see the infill with it as a newbie.
That PLA looks great. No bubbles and it obviously wasn't brittle. Humidity isn't a problem in NorCal
PETG on a stock E3 is fine, just more heat, more retraction and print a little slower ABS needs an all metal hotend, because that little piece of tubing in the stock one will cook at ABS temps
![]() Join Date: Dec 2009
Good looking print.
I had a similar experience with an E3. I passed it on to a coworker. I will get another (different) one later. The settings from Thing a verse or the prints I designed would be a 50/50 shot. ![]() I got used to turning up the heat and increasing the infill. It was defiantly a learning experience.
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
![]() Join Date: Jan 2025
Nice, now do a raised GM or Chevy logo in the center or a complete fake OEM radio.
1972 C10 Custom Deluxe Highlander 402 Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
