Old 02-17-2025, 10:26 AM   #1
5Tractorguy
5Tractorguy's Avatar
Upholstery and Interior Questions
Hey guys, I'm planning on doing an extensive mechanical revamp once spring gets here on my '61 GMC and was hoping some of you can help with a few questions I have...
First, for those that have rebuilt the standard bench seats (ones with the thin foam)...
- What thickness/density foam did you use? I read the back takes 1" and the seat portion 2"... I'd really like to firm up the seat and wasn't sure if I could add an extra 1/2" to 1". Thinking of ordering everything off this site... http://www.diyupholsterysupply.com/
- Or did anyone buy the kit from Classic Industries? (https://www.classicindustries.com/pr...s/ak50104.html) And if so, how was the quality?
- Anyone use this cover from LMC? If so, decent fit? This is a work truck so it doesn't have to be perfect... https://www.lmctruck.com/interior/se...upholstery-kit
And lastly, do the arm rests all use the same bolt pattern? I'd like to buy the 64-66 rests because they are significantly cheaper than the 60-63 rests. Read the 66 and up rests are the only ones that are different but wanted to confirm first.
64-66 rests on Ebay
Size:  43.2 KB Name:  IMG_0825.jpg
Jake
5Tractorguy on Youtube
5Tractorguy is online now   Reply With Quote
Old 02-17-2025, 11:08 AM   #2
DPowers
One foot in front of the other
DPowers's Avatar
Re: Upholstery and Interior Questions
Arm rests have same bolt pattern.
As for the other questions, I dont have any first hand knowledge.
DPowers is offline   Reply With Quote
Old 02-17-2025, 07:03 PM   #3
jweb
jweb's Avatar
Well I don't know about the foam or covers you mentioned but I do know a little about foam itself.
You don't want to make the cushion or back thicker. This will mess with how they fit together. It can also be an issue if you're tall, sitting higher isn't going to help.
Foam usually has a density and ILD rating ( see attached chart) .
We use this Q51 or Q61 as the base layer for all of our seats.
https://www.rexpeggfabrics.com/index...82%7C149%7C150
https://www.rexpeggfabrics.com/index.php?prodID=657
https://foamonline.com/wp-content/up...UEuNT17m9Vfc0d
I would recommend using a foam similar to these for the bottom, the back isn't as critical since you aren't applying much pressure.
1951 Truck, LS1/4L60
1964 Suburban, current project
jweb is offline   Reply With Quote
Old 02-17-2025, 09:50 PM   #4
5Tractorguy
Appreciate the info DPowers! That saves me from having to buy the expensive arm rests...
And I am tall, would be a bummer if I kept bonking into the roof. Thank you for all the info here Jweb! That's what i was looking for and needed to better understand. I'll go with the original thicknesses, but just one of the higher densities you recommended.
Jake
