Old 02-18-2025, 06:11 PM   #1
IT Cowboy
IT Cowboy's Avatar
Location: Clarkdale, Arizona in a van down by the river
Is tuning a quadrajet as easy as getting max vac and setting idle
I just watched a video on how to do a basic tune on a quadrajet using a vacuum gauge. It shows that you set the front mix screws one at a time until you have max vacuum on the gauge and then set the idle screw to the desired rpm.
Is this something I can attempt without really messing something up? My truck seems to be running rich and smells like gas under the hood when running. I looked for leaks in all the normal places so I thought I would check the air/fuel mix adjustment vacuum first and then the timing.
https://www.youtube.com/watch?v=Nbih0zm_Ldw
'72 C10 / 402
___________________________________________
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is offline   Reply With Quote
Old 02-19-2025, 03:26 PM   #2
GSP7
GSP7's Avatar
Re: Is tuning a quadrajet as easy as getting max vac and setting idle
There's more to it than that if you just installed a new rebuilt Qjet from someone else
I just finished a Qjet rebuild using Cliff Ruggles parts
Waiting for the weather to get better so I can do some intake manifold pressure wash cleaning and get to R&R'in. My shop is snowed in.
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4,
Pinstriping-Lettering-Specialty Painting
GSP7 is offline   Reply With Quote
Old 02-19-2025, 04:16 PM   #3
IT Cowboy
IT Cowboy's Avatar
My vacuum gauge attached to the front pcv port is at 15 steady at idle if that says anything
'72 C10 / 402
Old 02-19-2025, 05:16 PM   #4
Badride76
What more is there to adjusting it?
Badride76 is offline   Reply With Quote
Old 02-19-2025, 05:34 PM   #5
GSP7
GSP7's Avatar
Go here for answers:
https://cliffshighperformance.com/si...orum/index.php
Old 02-19-2025, 07:12 PM   #6
Dead Parrot
All that adjusting the idle mix screws does is adjust the idle mix. The idle speed screw sets the idle speed. Neither has anything to do with running down the road tuning.
Things you can do from the outside also include picking which accel pump hole to use and making sure the choke is set correctly as well as the fast idle speed.
IIRC, you can swap the rods and hanger for the back two secondary barrels.
You have to open it up to change the primary jets and rods which is where the main tuning effort happens.
Also, set timing first. For a stock SBC, start around 8~10 and increase until it gets hard to start hot. This may take several days as adjusting the dizzy while leaning over a hot motor is not a lot of fun.
Dead Parrot is offline   Reply With Quote
Old 02-20-2025, 11:19 PM   #7
IT Cowboy
IT Cowboy's Avatar
Again my vacuum reads 15 counted to the PCV valve port. The timing says it is right at 10 degrees so it might need some tweaking or that 15 vacuum might be normal for my setup
'72 C10 / 402
Old 02-20-2025, 11:34 PM   #8
cadillac_al
Most of my engines pull around 18. The 350 in my K20 pulls 21. My GMC pulls 15 and I am kinda disappointed but it runs perfectly fine. I can't figure that one out but it does have 190k miles. Never had a 350 with that many miles. Back in the day a lot of carbs got rebuilt because of bad points. If you have points and haven't changed them yet then you need to.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old Yesterday, 12:20 AM   #9
Dead Parrot
PCV port is a poor place to measure. Better to use the manifold port on the front of the carb and have the PCV valve hose in place.
Is that 10 degrees with the dizzy vacuum pot disconnected? Yes is the good answer.
18~20 inches is more normal for a stock cam with vacuum pot connected to manifold vacuum. Non stock cams often have less idle vacuum.
Old Yesterday, 06:41 AM   #10
IT Cowboy
IT Cowboy's Avatar
Possible take into account that this is using a $18 gauge from harbor freight and on the front PVC port
'72 C10 / 402
Old Yesterday, 04:57 PM   #11
IT Cowboy
IT Cowboy's Avatar
I finally found someone locally to tune and work on my truck. He took a look today and said the throttle linage into the carb is loose and that can be a big vacuum leak. Just by looking at the motor he could see what had been changed etc. and mentioned like 17 different adjustments on that carb.
'72 C10 / 402
