Old 01-23-2025, 05:19 PM   #651
regan wilson
regan wilson's Avatar
Re: 67 Camaro Build
The car looks awesome. I can't wait to see the finished product.
NHRA Super Street 469C
It only runs 10.90 at 156 mph
I was Dragtruck when Dragtruck wasn't Cool!
regan wilson is offline   Reply With Quote
Old 01-24-2025, 09:45 AM   #652
Lost in the 60's
Lost in the 60's's Avatar
Re: 67 Camaro Build
Aftermarket push pins and original size holes don't play well together. I know you don't want to size those holes up for the pins, but I've found they hold much better than shaving all the ribs off from forcing them thru a hole being too small.
Lost in the 60's is offline   Reply With Quote
Old 01-26-2025, 09:42 AM   #653
7dee2
7dee2's Avatar
Re: 67 Camaro Build
Thank you Regan. Final assembly is the best, it's cool seeing it become a car.
With the aftermarket body tub, I felt fortunate that there were any reference holes at all!
Finishing up both sides. I decided the same style screw used to attach the weatherstrip channel would work better than push pins.
Brett
67 Camaro SS: 67 Camaro Build
72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build
72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 01-29-2025, 11:13 AM   #654
7dee2
7dee2's Avatar
Re: 67 Camaro Build
Eyeballed the right quarter window, the final adjustment must wait till the door glass is present. I had just a heck of a time with the speedometer cable firewall grommet. Could not for the life of me get it to clip on correctly. After several tries, I made one from an extra universal one that I had on hand. That finally worked out, so I painted the retainer clips, ran the speedo cable, and was done.
Brett
Old 02-02-2025, 09:56 AM   #655
7dee2
7dee2's Avatar
Re: 67 Camaro Build
Ditto with the left quarter window install (eyeballed). Next, I installed the new AAW bulkhead/dash harness and found the repro firewall has a larger opening than the original. I confirmed this by measuring the gasket impression on our original harness, surprise!
Brett
Old 02-05-2025, 10:50 AM   #656
7dee2
7dee2's Avatar
Re: 67 Camaro Build
Yep, daylight on both sides of the fuse box dagnabbit. We can’t have that, took a minute to decide just how I'm going to fix this. In the meantime, I popped the dash speakers back in along with the Y-duct and the firewall insulation, double checking everything. I’m still fitting the driver’s side firewall insulation for the final install. Last pic is strip caulk/dum dum on the backside of the speedo cable clips.
Believe me, I will seal up this firewall!!!!!
Brett
Old 02-09-2025, 12:32 PM   #657
7dee2
7dee2's Avatar
Re: 67 Camaro Build
I think the best solution is to make a bigger gasket. Using an original as a template and some of this sticky foam material (also used on the dash speaker mount). We’ll see how this works out.
You may have noticed the “Xtra WW” blue tape stuck to the firewall. That’s the area where I’ll add a AAW 6-wire bulkhead. This will make it so I don’t have to modify the new dash wiring harness for the aftermarket windshield wiper motor, fuel pump controller, etc. etc.
Brett
Old 02-12-2025, 11:06 AM   #658
7dee2
7dee2's Avatar
Re: 67 Camaro Build
A few minutes with the die grinder made short work of this hole enlargement.
Brett
Old 02-16-2025, 01:55 PM   #659
7dee2
7dee2's Avatar
Re: 67 Camaro Build
To quote Spicoli “Hey, I know you!”, it’s been a minute but Perks has paint on the SS hood and the OE 67 (no spoiler) trunk lid. They must’ve had issues with the spoiler and vent panel, as these pieces were held back until this round. It's worth the wait, this stuff looks great!
Brett
Old 02-19-2025, 10:29 AM   #660
7dee2
7dee2's Avatar
Re: 67 Camaro Build
Our original Y-duct was missing the lower bracket. Doesn’t appear to have ever been there but I remedied that for the final install.
Brett
Old 02-20-2025, 09:05 AM   #661
Lost in the 60's
Re: 67 Camaro Build
If that Y is from a console car, it would have another plastic piece directing airflow to the throttle pedal and passenger footwell area and has a tab to hold it and the Y in place to the sheet metal.
