Junior Member
![]() Join Date: Jul 2023
18 guage hand held hole punch for replacement panels
I have looked hi and lo for a hole punch that will pierce 18g metal
I have only found ones that handle 16g I don't want to drill. Can anyone steer me to a HAND HELD punch for 18g A pneumatic tool I is not what I want. The hand held tool that has rotating wheel with the different hole diameter sizes. |
Re: 18 guage hand held hole punch for replacement panels
16g is heavier than 18.
Ron
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
![]() Join Date: Jun 2005
Yep, like wire, the smaller number the larger the size.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
Junior Member
Wow. Just electric wire sizing
I'm so glad I'm a member of the forum. Lastly, do you all use .023 mig wire for the panel welding ? |
I typically use .030 on sheet metal. And then .035 on thicker steel.
The thing about welding thin sheet metal is practice practice practice on the same gauge sheet metal before welding on your project. |
![]() Join Date: Mar 2018
If you already have 023 it will work just fine. Don't use flux core wire it is dirty. Using 25% carbon dioxide 75% argon gas for black is the cleanest.
My bad I was backwards on the blend brain fart. Thanks raggedjim. Last edited by Rick Bollinger; Yesterday at 09:17 PM. |
![]() Join Date: Jun 2002
Hmm, I always use 75% argon, 25% CO2.
I use .030 for floor panels but usually use .023 for outer body panels. I have used flux core for floor panels but you get a lot of splatter. If you have a flux core/mig machine make sure you select the right polarity for mig. Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
#8 | |
