Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 11-25-2024, 04:01 PM   #51
hevy_chevy67
hevy_chevy67's Avatar
Re: 1970 Blazer Build
The 6.2/6L80E combo will make it move! 400hp and good gearing with relatively low weight is a recipe for performance.
I'm hoping! I'll be running 3.73 gears in it.
1971 Chevrolet K10 - SWB, 5.3LS, 4L60e
1970 Chevrolet K5 Blazer - Project
1969 Chevrolet C10 - SWB, 350 Holley Sniper, 700r4
1969 GMC Suburban - 5.3 LS, 4L60e
hevy_chevy67 is offline   Reply With Quote
Old 11-29-2024, 08:13 PM   #52
Ricky Rodder
Ricky Rodder's Avatar
Coming along nicely
Ricky Rodder is offline   Reply With Quote
Old 12-01-2024, 02:30 PM   #53
hevy_chevy67
Getting things mocked up. Need to do some hinge work on the slots to get the doors dialed in yet
Old 12-14-2024, 09:49 PM   #54
hevy_chevy67
Getting a little further along in getting sheet meal hung. Also had to put on tires for some extra motivation.
Old 01-07-2025, 04:59 AM   #55
dec010974
dec010974's Avatar
Hello hevy_chevy67. Happy new year. Is that a true, K5 Blazer, 4WD frame? If so, how did you locate the hole for the Trailing arm cross member? Do you have measurements or a guide? I want to use your blue print. Thanks in advance, Clark.
dec010974 is offline   Reply With Quote
Old 01-07-2025, 11:02 AM   #56
hevy_chevy67
Yes, my frame is an original 4WD frame.
It was a while ago since I placed the crossmember, but I'm 99.9% sure there was an existing hole on each side I used. I then had to drill the remaining ones. Here are a couple pics I have saved of my front and rear crossmember, the bolts in each picture used an existing hole to get the proper placement and then I drilled new ones for the remaining.
Old 01-13-2025, 03:03 PM   #57
hevy_chevy67
Started putting the front end together. I had a set of control arms and crossmember powder coated, so I put those together along with 2" drop springs and drop spindles.
Ripped out the engine & trans from the Yukon donor. I was planning to part it out but the FB Marketplace idiots and messages were in full force. Not worth the headache and effort so I sold the whole thing as is and re-couped a bit of my cost. He picked it up on Sunday so at least its gone and down the road.
Old 01-16-2025, 11:43 PM   #58
dec010974
dec010974's Avatar
Hello hevy_Chevy67. Happy new year. What are you gonna do for the steering link, as it pertains to the idler arm/pitman arm that connects to the center link. I’m converting a 4WD Blazer to 2WD and the passenger side doesn’t have frame indentations to accommodate the idler bracket. I made a template, drilled the (2) holes. The other option was to use a c10 rack and pinion kit . LMK what you think.
Old 01-17-2025, 11:02 AM   #59
hevy_chevy67
I haven't really looked at that yet, I'll have to take a look soon.
Do you have a pic of what you did?
Old 01-23-2025, 03:03 PM   #60
hevy_chevy67
Took everything apart again. I should have done it before, but I took the front 1/2 of the tub in to get sandblasted. Some metal work to do and then I'll raptor line the bottom of the cab before setting back on the frame.
Old 02-09-2025, 02:28 PM   #61
hevy_chevy67
I don't have much experience with a welder but I'm learning. After getting the front half of the tub blasted, it needed some work. The inner piece of the windshield header panel was Swiss cheese with some terrible repairs from a previous owner. Filled with body filler. Anyways, drilled out all the spot welds and took the old piece off. The outer ones were in really good shape, not sure why the inner one went bad. New one one back in and started repair on the radio holes that were cut out. Some grinding needed yet but looks better.
Old 02-23-2025, 01:08 PM   #62
hevy_chevy67
Sent out my 6l80 to get refreshed and a 2wd conversion a couple weeks ago and it came back. Resealed and cleaned up the 6.2 today and placed into the frame.
Old 02-23-2025, 03:10 PM   #63
jaros44sr
jaros44sr's Avatar
Nice work on the windshield frame, mine is Swiss cheese as well
Where did you get the repair panel
Nice work so far
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 02-23-2025, 03:30 PM   #64
hevy_chevy67
Nice work so far
Thanks.
I got it from Jegs, it is Key Parts which is the brand I've used for my doors and front fenders.
For whatever reason, it is almost 1/2 the cost of the brand AMD carries on their website. I only used the inner piece but I have no idea why the big price difference.
Old 03-08-2025, 03:41 PM   #65
hevy_chevy67
Some more work on the cab done. Floor patch put in and got the underside in epoxy and raptor liner.
Old 03-09-2025, 10:31 AM   #66
jaros44sr
jaros44sr's Avatar
Originally Posted by hevy_chevy67 View Post
Thanks.
Thanks for saving my money I just hate to pull my w/s and the can of worms that that opens up
Just might live with the rust falling into my lap for a while longer
I have the same problem with my radio/ dash, bought a OEM used dash patch years ago just haven’t got aroundtoit
Nice work on your sheet metal work
SAFETY FIRST
AS usual, off topic
Jim
Old 03-10-2025, 10:41 AM   #67
dec010974
dec010974's Avatar
Good morning hevy_chevy67. I hope all is well. Wow. Your build is exactly like mine. My LS motor will not fit. I am using the same ls kit (Speedway). I am also using the same factory crossmember. It appears that my motor needs to be raise an inch. Is your engine touching the center drag link?
Old 03-10-2025, 11:40 AM   #68
hevy_chevy67
I haven't put in any of the steering components in yet, so I can't confirm. I may need to mock things up shortly and find out. Now I'm worried lol
Old 03-10-2025, 11:50 AM   #69
hevy_chevy67
Do you have any pics of where you mounted for idler arm to the frame?
Old 03-11-2025, 06:58 AM   #70
dec010974
dec010974's Avatar
Actually I have saved you the template and kit. I made the template off of a 2WD truck frame. You can test/check the measurements to make sure you have the proper placement. My blazer was originally a 4x4 and I converted it to 2WD by removing the front differential and adding a 2WD drive cross member. If I had it to all over again, I would’ve went with a IFS kit.
Old 03-11-2025, 10:13 AM   #71
hevy_chevy67
Where was your engine touching?
Old 03-11-2025, 04:32 PM   #72
dec010974
dec010974's Avatar
I have pics of the idler arm and template. I can send it to you if I had your address. I can also add the flat bar.
Old 03-11-2025, 04:35 PM   #73
dec010974
dec010974's Avatar
Pics can’t be posted because of missing tokens
Old 03-12-2025, 01:35 PM   #74
hevy_chevy67
I'll send you a PM.
Old 03-14-2025, 08:59 AM   #75
dec010974
dec010974's Avatar
I will send you the template and bar. No biggy. Just give me your address. Moving forward, I cut the speedway engine mounts and made perches that raised the engine, to the frame crossmember, and correcting the drive line angle. The engine was laying center link using the original speedway mounts. I also purchased these Camaro mount to see how the fit. Lastly, where would you place angle finder, to find the rear differential pinion angle? I'm thinking one of those lines on differential case.
