Old 01-04-2024, 02:11 PM   #476
Keith Seymore
Keith Seymore's Avatar
Re: The build date project
Having said that, I'll take a swing at these:
Originally Posted by 402Bowtie View Post
Some questions for both of you:
1) The sequence number is in on the top left of the build sheet, above the date, correct?
Normally it's specifically labeled, but yes.
2) At what point is the build sheet printed with the serial number? It seems like the serial number would have to be included fairly early in the process or otherwise perhaps printed on the build sheet after some assembly has been completed?
Early in the process, like before the build is started. All of the build sheets and manifests are printed and distributed a day or so before the build starts.
Just to be clear: to me "serial number" = "sequential portion of VIN"
3) Pretend I have two build sheets. One is sequence number 17647 (w/ s/n 2Z120845) and the other is sequence number 17699 (w/ imaginary s/n 2Z120897) and they both show a 11/12/71 build date. I think you are saying that is 100% safe to assume that sequence numbers in between those two were built on 11/12/71.
Sequence number = Yes. By definition. Because even if you have re-ordered the VIN/Serial numbers the new build sequence numbers are still going to count up one by one
However, at some point along the way, one of the sequence numbers could have been assigned a serial number outside the range of 2Z120845 and 2Z120897, or at least in a non-consecutive manner. Is that correct?
Yes. Although in this case it is the VIN/serial number that exists and is assigned a new sequence number (not the other way round).
4) For 100 consecutive sequence numbers, how many of those trucks are likely to have consecutive serial numbers?
Depends on the plant (because of the accumulators and buffers, and lack thereof).
Fremont - 99%
Flint - 60-80%
Maybe I'll start trying to include sequence numbers. Any other sources for the sequence number besides the build sheet? Firewall? SPID?
Firewall - yes. Any place where components were assembled off line and conveyed in sequence to the main line: Front end sheetmetal, radiator support, grille, axles, tire/wheels, seats, etc. But - it will typically be the last two or three digits of the sequence number, in a form of shorthand. Not the full six digits of the full sequence number.
SPID - no. The sequence number does not appear on the SPID
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-04-2024, 02:41 PM   #477
Keith Seymore
3) Pretend I have two build sheets. One is sequence number 17647 (w/ s/n 2Z120845) and the other is sequence number 17699 (w/ imaginary s/n 2Z120897) and they both show a 11/12/71 build date. I think you are saying that is 100% safe to assume that sequence numbers in between those two were built on 11/12/71. However, at some point along the way, one of the sequence numbers could have been assigned a serial number outside the range of 2Z120845 and 2Z120897, or at least in a non-consecutive manner. Is that correct?
At the risk of overdoing let me try a different approach.
We are talking about the relationship, or lack thereof, between the build sequence number and the VIN/serial number.
Vehicle orders are sent from Central Office to the plant in a strange six character code (see below). The order number is the tracking mechanism until the PVI, or Primary Vehicle Indicator, is established. The PVI is pulled in a sequence and are used to identify the vehicle until the VIN is established. The serial portion of the VIN is also pulled in sequence.
These can be broadcast to cab shop at the start of build and maintain pretty much this order. However, here is where the fun starts:
The vehicle/VINs can get shuffled after cab shop before paint, and again after paint but before trim but the build sequence number still counts up one by one.
In other words - there is a unique cab shop sequence counting up one by one, and then a unique paint shop sequence counting up one by one, and then comes the final line (General Assembly) sequence number counting up one by one - the one everybody cares about.
I didn't want you to think that the GA build sequence number is jumping around. It is not (barring some catastrophe where a vehicle needs to be pulled completely from the system and reinserted later).
The best analogy I can think of is writing checks: you write the checks in sequential order - pretty much always - but they do not necessarily clear the bank in that order.
The PVI and corresponding VIN/Serial numbers are pulled sequentially - but they do not necessarily clear the end of the line in that order.
K
1979-1986
1986 - 2019
Old 01-04-2024, 08:35 PM   #478
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Good stuff. Hey man, if you're starting to track sequence number I got one for you, it's 24419 Kidding, my build sheet only shows five digits, should be six, they missed the first digit. Serial # is 654xxx
From here, I don't think there's enough solid data to add value for tracking sequence number, especially since in at least one case, only 5 of 6 digits are shown. Hmm, might shed some light similar approx. build months per available data, not sure.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 01-05-2024, 12:29 AM   #479
Getter-Done
Getter-Done's Avatar
Originally Posted by Keith Seymore View Post
This is correct -
A guy might have a "main job" like "Fender Set", or "Spare Tire Hang", or "Battery Install" but after they complete that part there are little wires to connect or route; other small things to fill out those extra few seconds.
K
Totally understand. I had a SunRoof job on the ALl Tima.
If you had 10 in a row We was 2 Zones down line.
I got to know some of my Fellow workers though.
40 years for me; across about a dozen different GM assembly plants (Flint, Pontiac, Ft Wayne, St Louis, Janesville, Oshawa, Fremont, Arlington, Silao, Wentzville, Mishawaka, Hamtramck come to mind)
There is no shortage of things in a vehicle assembly plant to capture your imagination, if you are a car guy.
K
I was Very involved in the ( Kizanes) / Changes of Models and Etc.
One of the biggest Improvements I suggested was ,
I had a Job installing Mirrors.
If the mirror was (No Good).
The back up Stock / Rack was Disorganized.
I helped them set up a Rack for this mess/
Because A truck going down the line without a Mirror ,
It Got covered up Quick. Door panel and Etc.
I helped designed a Back-Up rack for
Every paint Color. and
And Both Options.
Power mirror
Non Power mirror
Chrome mirror was also included.
Then 12 Paint colors.
There was 20+ mirrors that were Required.
So I asked for a Rack of 7 long and 5 slots high .
This way there was 3 rows that were used for the High Users at the time.
I gain a lot of Knowledge from there Crazy way of doing Business.
The early bird gets the worm,
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 01-05-2024, 08:10 PM   #480
71CHEVYSHORTBED402
I should add, seems the missing first digit is 6. If so that's 30K short of the serial number.
Interesting to note you have a duplicate under 1971 Freemont, which is my truck I tried to be sneaky and gave you a serial number within 100 . I don't know how you found my build sheet without part of the serial redacted. The unredacted sheet is on post 435. I must have shared it someplace. I'll try to get over my paranoia.
So you can delete the record that reads "1Z654520 = 05/19/71 *serial number is within 10". Or vise versa, whatever you like.
I had to re-write some of this, my understanding of was messed up:
For "real life" comparison, the records show another Freemont truck built on 5/19/71, post 352. Both build sheets show 24 as the Job Sequence Number, next to the build date, I don't know what that means in practical terms. Looks like it was common for them to drop a digit from the sequence. That or the logic is a mystery to me short what's described above. Note the lag in sequence numbers as compared to the serial numbers, a difference of 20.
The K truck is a SWB Chevy, seems that's irregular, I don't suppose many of those were built? My C10 was special ordered with leaf springs on a SWB 2WD, pretty rare frame and combo. Perhaps they were grouped together somehow, because both builds were uncommon.
Here are the differences between the two trucks. On a side, coincidentally, 5/19/1971 is the date on coolant decals for what's supposed to be for 1971 & 72 trucks. Thus, most 1971 trucks including these would have had the previous decal.
Great job adding page numbers, as demonstrated by this.
Tony
Old 01-25-2024, 07:16 PM   #481
402Bowtie
402Bowtie's Avatar
2J158913 = 05/72 (post 481)
2F160354 = 03/24/72 - 03/31/72 (post 481) Blazer
1B650804 = 06/11/72 (post 481)
1J634982 = 05/71 (post 481)
8Z139537 = 03/01/68 - 03/18/68 (post 481)
402Bowtie is offline   Reply With Quote
Old 02-01-2024, 01:38 PM   #482
402Bowtie
402Bowtie's Avatar
1J643533 = 06/71 (post 482)
01134504 = 03/70 (post 482)
2F111337 = 09/71 (post 482) suburban
8Z152044 = 04/27/68 (post 482)
9S866625 = 06/24/69 (day 175 ?) (post 482)
Old 02-10-2024, 10:17 PM   #483
yote1234
yote1234's Avatar
heres my 1971 k5 blazer built 6/71 KE181S673516
1971 K5 CST Blazer
1965 Chevelle Malibu 283 (sadly sold)
1968 Camaro 327
1968 Honda mini-trail z50a #377
1966 uh 1-D Huey
yote1234 is offline   Reply With Quote
Old 02-12-2024, 01:28 AM   #484
402Bowtie
402Bowtie's Avatar
7S191468 = 07/01/67 - 07/03/67 (post 484)
7J132287 = 02/22/67 - 03/10/67 (post 484)
8J113773 = 10/23/67 - 10/31/67 (post 484)
2F348544 = 02/17/72 - 02/29/72 (post 484)
2F346414 = 02/01/72 - 02/18/72 (post 484)
8S174755 = 03/22/72 - 03/31/72 (post 484)
Old 02-12-2024, 01:42 AM   #485
402Bowtie
402Bowtie's Avatar
2F1528XX = 03/72 (post 485)
2S503885 = 10/71 (post 485)
0Z126461 = 12/69 (post 485)
0J122359 = 11/69 (post 485)
7S194748 = 07/67 (post 485)
Old 02-12-2024, 11:32 PM   #486
402Bowtie
402Bowtie's Avatar
yote, I am going to leave that one off the list since it doesn't add any new information...we could have inferred a June '71 build date for that serial number based on the existing list.
I'm now updated through post 486! The updated lists can be found at the links below:
GMC on post 63
67-71 Chevy on post 64
72 Chevy on post 65
Reminders:
-Don't delete any posts that are prior to the most updated point of the thread. For example, if the list is updated thru post 435, don't delete any posts 1 - 435. That would be bad.
-Only post a serial number if it adds value. For example, a door sticker with the month of 11/71 doesn't provide value if its serial number is in between two other November serial numbers already on the list.
-Check the list before posting to see if the serial number is already on the list--there have been a lot of duplicates posted.
-Please type out the partial vin, the date, and the post #, ideally in this format: 2A103580 = 09/71 (post 314). This saves me a lot of time when I can copy and paste.
_________________
7S148684 = 02/14/67 - 02/28/67 (post 486)
7B148429 = 06/67 (post 486)
1F811266 = 03/24/71 - 03/31/71 (post 486)
2J507165 = 02/14/72 - 02/29/72 (post 486)
7Z151494 = 04/28/67 (post 486)
Old 02-16-2024, 06:01 PM   #487
402Bowtie
402Bowtie's Avatar
8J128287 = 01/09/68 - 01/31/68 (post 487)
0B161446 = 06/70 (post 487)
7S151229 = 02/21/67 - 02/28/67 (post 487)
2S199321 = post-06/07/72 (post 487)
9B811984 = 09/29/68 - 09/30/68 (post 487) I think the two equipment codes are 09/29 and 09/19. Month code of 9.
Old 02-23-2024, 11:20 PM   #488
CKfan
Post 488
68 Fremont truck KE148Z 110596
Scheduled date: 10-05-67
Production date: 10/10/67 (which I rarely see on build sheet) PIC #4
Crazy documentation and "3" build sheets and protect o plate.
No, not mine. I taped out of the bidding war.....sadly. May regret it someday, but not today
CKfan is offline   Reply With Quote
Old 03-01-2024, 01:58 AM   #489
72BBChuck
72BBChuck's Avatar
Post 489
GMC
Freemont
2Z510866 - 4/72
72BBChuck is offline   Reply With Quote
Old 03-01-2024, 02:02 AM   #490
72BBChuck
72BBChuck's Avatar
Question - is the date on the protecto plate the date the truck was sold?
Old 03-01-2024, 07:54 AM   #491
mr.mud1
mr.mud1's Avatar
good day sir,the date on the blue door decal is the manufacture date.that isn't as far as i know,the Protecta-Plate.my understanding has always been,the Protecta-Plate is the metal plate with all the numbers stamped in,on the back page of the warranty booklet.i don't have the PP for my truck but i do have it for my 67 Impala wagon,i can go look but i know the vin,engine number is and some other info is stamped in there but i'm not sure about the sale date but i'll go look.
mr.mud1 is offline   Reply With Quote
Old 03-01-2024, 09:28 AM   #492
402Bowtie
402Bowtie's Avatar
Yes, believe so.
Old 03-15-2025, 10:52 PM   #493
402Bowtie
402Bowtie's Avatar
No meaningful build date info, but interesting in that it is the last 72 St. Louis Blazer on the list currently.
Old 03-16-2025, 07:18 AM   #494
1970cstblazer
1970cstblazer's Avatar
1970 K/5 Blazer
St. Louis build
S154197 3/70
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 03-16-2025, 07:29 AM   #495
1970cstblazer
Arrow Re: The build date project
1970 C10 from BAT
St. Louis Build
S154562 3/70
Old 03-16-2025, 07:38 AM   #496
1970cstblazer
1970 C10 Oshawa from BAT
1136736 4/70
Old 03-16-2025, 07:52 AM   #497
1970cstblazer
1970 K20 Oshawa build from BAT
1134504 3/70
Old 03-16-2025, 09:58 AM   #498
402Bowtie
402Bowtie's Avatar
1134504 3/70
This one is already on the list. The Canada ones add value, but the others could have already been inferred based on existing data. See post 486 above for more details. Thanks for posting!
Old 03-16-2025, 01:18 PM   #499
awryexperiment
Out of curiosity, where can one find the "list".
awryexperiment is offline   Reply With Quote
Old 03-16-2025, 01:33 PM   #500
402Bowtie
402Bowtie's Avatar
GMC on post 63
72 Chevy on post 65
