Old 03-22-2025, 06:20 PM   #1
Luke87gt
Luke87gt's Avatar
Recommend a Brake Booster / MC Please
Hi guys, my truck is 69 i6 with 4wheel drums (manual)
I will be upgrading to CPP drop spindles and front 6-lug brake upgrade (I plan to add power brakes). Rears will remain drums.
Can you recommend a MC/Booster combo for me, preferably something I can buy on Rockauto? Should I be purchasing a 71-72 booster/MC? Any particular size booster recommended?
Also, if someone can steer me in the right direction for the proportioning valve below the MC that would help? Can I reuse the stock one?
1969 C10 Shortbed
Luke87gt is offline   Reply With Quote
Old 03-22-2025, 06:45 PM   #2
Willshook
Re: Recommend a Brake Booster / MC Please
I went with the CPP complete bracket/booster/MC/prop valve and it's a great piece for a great price.
The only caveat is that the pin for the booster is larger than stock...so if you buy this, your only solution for a replacement booster is theirs. Learned this the hard way, although it did say that in the catalog and I missed it.
Willshook is offline   Reply With Quote
Old 03-22-2025, 06:47 PM   #3
dmjlambert
dmjlambert's Avatar
I am more familiar with converting 69 to front disc brakes with 5-lugs and putting conversion axle shafts on the rear to make them 5-lugs as well, and I went with manual brakes; I specifically did not want power brakes. So I may not be able to help with all of that, but I can say your 69 with all drum brakes doesn't have a proportioning valve, that is a distribution block and brake warning switch. Are your front brakes going to be disc brakes? If so, for proportioning I bought an original 71-72 combination valve from the parts section here in this forum, and sent it off to White Post Restorations to have them restore it, and I like it quite a lot. If you have original 6-lug steel wheels for 1969 I believe those won't work with disc brakes, just so you know.
Old 03-22-2025, 10:10 PM   #4
Luke87gt
Luke87gt's Avatar
CPP is perfectly fine but if I wanted to utilize OEM parts, could I use 71-72 booster/MC?
1969 C10 Shortbed
Old 03-23-2025, 09:13 AM   #5
A1971Blazer
A1971Blazer's Avatar
I got one of these from Frank here on the forum.
Very happy with it!
A little more expensive than a box store or RockAuto unit but well worth it
https://67-72chevytrucks.com/vboard/...hlight=booster
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 03-23-2025, 10:34 AM   #6
72c20customcamper
72c20customcamper's Avatar
Very happy with it!
I’ve used his products on two of my trucks . It’s so nice to have a unit that is just a direct replacement no fiddling around with brackets and hardware .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 03-23-2025, 09:06 PM   #7
Rust_never_sleeps
Rust_never_sleeps's Avatar
I used CPP drum-disc kit, but I bolted on MBM's "booster conversion kit"
Nothing special, but works fine, and MBM's online docs are pretty good
A fair number of folks have problems with generic boosters and combo valves ootb, so if you've got the budget to jump up to Baer/Leeds/Wilwood as insurance against timesuck, it might be worth it
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is online now   Reply With Quote
Old 03-23-2025, 09:09 PM   #8
burb71
Active Member
I got my booster/master cylinder here on the board from Frank
About four or five years ago, still works great.
burb71 is offline   Reply With Quote
Old 03-23-2025, 09:42 PM   #9
weq92f
weq92f's Avatar
Soooo wish I'd went this route rather than replacing one piece, then another, then the next over time and all the parts just don't really work well together.
I'll be back to revisit this sometime in the future and I will just replace the whole thing all at once.
-Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 03-23-2025, 09:50 PM   #10
Luke87gt
Luke87gt's Avatar
I’ll reach out to Frank
Although I must admit, I thought this was going to be an easy/cheap piece together on RockAuto from a 71-72
What exactly doesn’t work from the 71-72 and why? Thanks
1969 C10 Shortbed
Old 03-24-2025, 10:24 AM   #11
72c20customcamper
You would need to piece together all the brackets and the linkage now add a rebuilt power vac and new master and a new portioning valve you would most likely be at the same price point .
It took me less than a half day to put the power brake unit on my 68 .
The only thing I had to get was the flare adapters for the brake lines . I was going to change all the lines but since this is a New Mexico truck the original lines were perfect.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 03-24-2025, 11:45 AM   #12
MikeB
MikeB's Avatar
Yes. My 69 has a 71-72 booster, master cylinder, combination valve, and brackets are from a junkyard truck. I installed it all back in the 90s. Over the years I have replaced the master cylinder and combo valve, and had the OE booster rebuilt. But that was after the OE parts were 30-50 years old.
71-72 OEM booster is 11" diameter and the master cylinder has 1-1/8" bore.
Here's a couple photos that might help. Yes, the aftermarket switch isn't connected yet because it's a 73-up connector.
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 03-24-2025, 02:32 PM   #13
Rust_never_sleeps
Master Power is another brand of power brake kit, seems comparable to the MBM
Kits include the linkages and the bell crank mount gizmo.
Never priced them separately, but off RA, you could certainly piece together this Centric M/C with a reman(Cardone etc) booster. Don't see combo valves on RA though so it's pretty far from a one-stop shop
https://www.rockauto.com/en/moreinfo...t=1836&jsn=782
