Rockauto Suspension: Moog or Mevotech?
Hi all, for stock replacement suspension parts like bushings, ballpoints, etc, are you guys still generally recommending Moog?
I’ve typically bought Moog but also had great luck with Mevotech. What Rockauto brands are you guys using for your stock suspension related parts these days? Thanks
1969 C10 Shortbed |
Re: Rockauto Suspension: Moog or Mevotech?
I continue to buy Moog; just rebuilt my entire steering system with their stuff.
Still outstanding, lifetime quality parts. |
Excellent, thank you for the reply.
1969 C10 Shortbed |
I prefer and have used only Moog parts on my steering and suspension in the past. January of 2024, I had to replace a tire because of unusual wearing. I took the truck in after tire replacement to have an alignment done. They couldn't do the alignment at the time because of worn out idler arm and inner and outer tie rods. Went to summit's webpage to order new parts. Parts total was like $186, that wasn't in the budget at the time, so I bought the house brand at O'reilies auto parts. They have held up just fine for over a year of daily use driving. I still would have preferred Moog parts though.
1968 C10 327, 3 speed manual, LWB stock height daily driver. 1968 C20 327, 4 speed manual, LWB stock height custom camper with heavy duty leaf springs rear, 50th anniversary edition. Hoping to press into daily drive status soon. |
The one thing I have run into lately - mostly with Summit - is non-Moog parts in Moog boxes.
This appears to be due to people ordering cheap stuff AND Moog, putting the cheap stuff in the Moog boxes, and returning them. Summit doesn't bother to inspect before shipping it right back out. Went through Hell on this with them, so just something to watch out for... |
Moog. And if you get parts that aren't Moog, send them back.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson 1972 K/5 Blazer CST 4WD 1963 Corvair Monza Spyder Turbo convertible 1995 Camaro Z/28 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
I redid my front end completely and used Moog Parts. It took me about 6 months to get everything as I'd order the different parts from Amazon as I had the overtime money to pay for them. Every box said made in the USA and when the front end was back together no problem with the initial alignment or issues and have put about 2000 miles on the truck since the install.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " In the end, we only regret the chances we didnt take " " Time is the only currency we spend without knowing the balance, use it wisely ." .. |
![]() Join Date: Jun 2005
Beware, some Moog parts are NOT made in the US of A. Always check before buying.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
I prefer Moog. I redid the front end of my 67 C20 and did a disc conversion as well. All Moog new old stock parts that were made in the USA. Perfect fit.
John 1967 C20 2WD Longbed 2001 2500 HD 4X4 Extended cab long bed
All about them K’s
![]() Join Date: Jun 2014
I used mevotech upper ball joints on my 98 K2500 with a 6” knuckle lift. The lift is notorious for killing upper ball joints on the those trucks. I get them because they supposedly have a beefier design over the others. Close to a A year and 10,000 miles and I have no complaints at all. I also have mevotech high operating angle front cv shafts in the same truck to deal with the tighter angles the CVs run with the lift. Again no issues at all. Moog is good too. I’ve used them a ton in the past.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
#11 | |
Always check country of manufacture first, don't just buy what used to be a good "name".
1987 V20 farm-hand rescue 1998 C2500 lot-rot rescue |
I believe the Problem Solver line is still made here, not sure about the rest.
I totally rebuilt the front end on my 67 when I converted it to disc brakes. Used the Moog Problem Solver parts. The only issue I had was the boots on the two outer tie rods split in less than a year. Other than that, it's been going on four years and about 4000 miles.
1967 C10 1997 Ford Ranger 2020 Toyota 4Runner 2024 Toyota Tundra |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
