Old 11-14-2023, 11:49 PM   #76
JamesRKing72
JamesRKing72's Avatar
Re: 71 Blue Jay
So I’m having (been having but avoiding) issues with the external voltage regulator (EVR). I replaced the old one about a year ago because it stoped working. The new one is points style regulator like the old one but it make so much noise. Didn’t think much of it at first but then the noise became sporadic.
I checked the voltage when it’s not making buzzing noise and it a healthy 13.5 or 14.5, can’t remember exactly now. It was good. Turned the engine off and restarted. EVR is now buzzing. The voltage from the brown wire in the EVR jumps between 8.2 & 11.3. The voltage at the red wire of EVR 14.8-15.5.
I’ve added lots of grounds, checked all the wires I can and patched and taped. Swapped the alternator. Got a new battery. Still not working correctly.
In reading about everyone’s EVR problems on here I’m thinking it isn’t playing nice with my HEI distributor. I may need to run a new hot wire to the distributor. Just ordered a solid state EVR to see if that will work better with the HEI distributor. If not I’ll reluctantly have to upgrade my alternator to a 12SI doohickey.
1971 Cheyenne, The Blue Jay.
The Blue Jay build thread-
http://67-72chevytrucks.com/vboard/s...d.php?t=516989
JamesRKing72 is offline   Reply With Quote
Old 11-14-2023, 11:52 PM   #77
JamesRKing72
Re: 71 Blue Jay
Originally Posted by Shifty One View Post
I'm digging your rescue of this fine old truck.
Hey, thanks shifty. I’m enjoying the work and looking forward to some long road trips.
Old 12-07-2023, 06:25 PM   #78
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: 71 Blue Jay
Glad to see you still plugging away at this..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 04-10-2025, 01:01 PM   #79
JamesRKing72
Re: 71 Blue Jay
Now I'm working on restoring the A/C system and already ordered some parts for an original look. So I have the A6 compressor and original looking hoses. I'll need the newer POA valve that will cycle the compressor on and off as the original was left open for 40 years and has too much dirt in it.
The problem I'm having is compressor brackets. Will the original brackets fit over the headers if I use some spacers? I will need to order some, I only have one of the 100 pieces for bracket set up.
I'm also thinking of going with R12 and using the original A/C condenser, after a good clean out.
350
Short Water Pump (5.660")
Headers
Aluminum Edelbrock Intake (performer I think)
A6 compressor
Original looking hoses (from LMC)
Old 04-11-2025, 08:20 AM   #80
clay68c10
clay68c10's Avatar
Re: 71 Blue Jay
Nice to see you're still working away on this one.
If you're going to use the A6 and R12, get a rebuilt POA valve and run it like original. You can also send yours in and have it rebuilt.
https://www.classicautoair.com/poa-v...s-cars-trucks/
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 04-11-2025, 08:06 PM   #81
JamesRKing72
Re: 71 Blue Jay
Hey, thanks for the link for the POA services. I have been struggling to find a place to clean mine up for me. :-)
Old 04-14-2025, 11:26 AM   #82
JamesRKing72
Re: 71 Blue Jay
Actually, they don't provide restoration services any longer. I sent an email in and got this response:
"Hello
Thanks for the email. Unfortunately, we no longer do any restorations. We closed our location in Florida location several months ago.
I do offer a couple POA valves on our website if you would like to take a look.
Thanks again
Steve
The search continues....
Old 04-30-2025, 11:36 AM   #83
JamesRKing72
Re: 71 Blue Jay
A/C system installed and cooling. A digital thermometer showed 28deg at one point in the air box. We will see how it works on the road once it stops raining here.
I did original brackets, except the bottom bracket, found one to work with the headers (Hedman 20110). Had to change out the heater hose inlet on the front of the water pump so the brackets would fit. A6 compressor 58098. I went with POA delete since my POA was full of dirt from being open to the environment for 45 years. R134A. New hoses from LMC. Only two original parts are the condenser and evaporator coils. I know, R134A doesn't like the old style condenser, I'll need to set up an electric fan in front of it to help with cooling it down faster. I may just get a cheap one and wire it with a on/off switch just below the A/C controls.
I also ordered some 20% tint and did the door windows to help with keeping the cab cool.
And a pic of inside the camper I built on the back. I'm sure I am forgetting something but I will just make another post about it when I remember.
1971, 350, cheyenne
