Old 05-07-2025, 12:06 AM   #1
nm78bronco
12 bolt true trac - how strong for towing.
I have a 1976 GMC 1/2 ton 454/th400/2WD suburban that I want to rebuild the rear axle. I want to tow with it, up to 5000 lbs and want to know if a Detroit true-trac is as strong a differential as a factory open-diff for the 12 bolt factory rearend. I live in the Rocky Mountains out west, so long pulls up hills will happen sometimes. I would be using a 3.73 gear ratio with the true-trac.
Does anyone tow using a 12 bolt with a true-trac? If so, how much weight do you tow that you’re comfortable with?
nm78bronco is offline   Reply With Quote
Old 05-07-2025, 04:24 PM   #2
LS short box
Re: 12 bolt true trac - how strong for towing.
Not even close to apples but I have used the Tru Trac on a number of LS projects. A couple that had close to 500 rwhp. Beat on the pretty hard. No failures.
I would suggest a new set of 30 spline Moser axles as long as you are in there.
Old 05-10-2025, 01:00 PM   #3
Pontiac1976
Pontiac1976's Avatar
1500lbs trails surge brakes 4200lbs car factory open 308gear 12bolt was 454 1977 now 305 no problem 1989-2006 ever weekend. I have driven this one hill is a kill on both motor unless you're doing 80 over the speed limit by the time you get to the ark of the hill you will drop 80 they both drove the same on that hill no power, just burn lots of gas there your rpm goes way up and no mph gain. I heard Tru Trac there pretty good.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 06-07-2025, 09:18 PM   #4
chris989
Like LS shortblock said,,
I have a TT in a 12 bolt 67 camaro,, 406/ ~550hp 4 speed car..
I beat the life out of it and the TT has never failed. When i replace the eaton friction posi's in my burb I will go TT.
I am also putting TTs in my 78 dentside.. can't go wrong..
Chris
chris989 is offline   Reply With Quote
