Old 06-14-2025, 06:24 AM   #1
csa daddy
csa daddy's Avatar
73 Cheyenne points to hei
Ok fellows I have a 73 Cheyenne that I'm changing to hei can I pull the number 3 wire from the firewall bulk head and replace it with a correct size hei wire terminal and all .
csa daddy is offline   Reply With Quote
Old 06-15-2025, 09:35 AM   #2
Axle
Axle's Avatar
Re: 73 Cheyenne points to hei
If #3 is the resitance wire lead, thats what I did on my '73 Nova when I converted. Just double check that there is voltage on that wire during cranking. Earlier years (at least passenger cars) did not and you still had to run the I wire from the starter to have coil voltage during cranking.
Alex.
Axle is offline   Reply With Quote
Old 06-15-2025, 12:56 PM   #3
csa daddy
csa daddy's Avatar
Actually it's position 105 by the diagram I have that shows it all . But thanks as soon as i can put tranny fluid in I spin it over and check what power I have
