Old 06-25-2025, 07:02 PM   #576
raggedjim
raggedjim's Avatar
Re: Previous owner '68
Originally Posted by wpsharpshooter View Post
Yes sir. Been here almost a month now.. And With the addition of the ac unit. I'm hoping the truck will be back in action in the next few weeks
Good deal, hope everything works out.
raggedjim is offline   Reply With Quote
Old 06-25-2025, 08:18 PM   #577
wpsharpshooter
wpsharpshooter's Avatar
me to.. This truck has been down over 3 years lol
wpsharpshooter is offline   Reply With Quote
Old 07-01-2025, 11:07 AM   #578
raggedjim
raggedjim's Avatar
So I had started welding up holes in the firewall to try to clean it up a bit. It's taken me awhile to decide what to keep and what to get rid of, hopefully I won't end up cutting them all back out!
I started with the seams at the panel joints around the window. Some people will say that if poorly mated panels filled with copious amounts of putty are good enough for GM then we should be happy with it. Sorry guys, that decision was made for the sake of assembly speed and because the bean counters wouldn't approve the time and money for full welds.
So I filled them with welding wire and marglas. Haven't got them prepped enough for paint but they aren't too bad.
Old 07-01-2025, 11:13 AM   #579
raggedjim
raggedjim's Avatar
I also welded the seams on the drip rail and tried to even it up as much as possible.
Old 07-01-2025, 11:17 AM   #580
raggedjim
raggedjim's Avatar
After welding the holes on the firewall I covered them all with fiberglass reinforced filler just because.
Then I drilled a 1/2" hole and used a square file to make it square for the cable style throttle.
Old 07-01-2025, 11:20 AM   #581
raggedjim
raggedjim's Avatar
Then I test mounted the gas pedal using a conversion plate. Not sure where I got the plate, I think I purchased it off of this board.
Old 07-01-2025, 12:11 PM   #582
loudchevy
loudchevy's Avatar
Looking good! I regret not welding the seams on mine. It looks way cleaner without the joint showing.
Scott
1970 C10 Restomod|454/700R4|LWB-->SWB Build Thread
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 07-01-2025, 12:20 PM   #583
raggedjim
raggedjim's Avatar
Thanks! This is the first time I've filled them in, I always used to just gloop in a bunch of sealant and hope for the best.
I've got to stop looking at other people's build threads, it has caused a bit ( a lot actually) of project creep...
Old 07-02-2025, 10:04 AM   #584
loudchevy
loudchevy's Avatar
The "project creep" is real for sure, but I think the "might as well" hits harder sometimes.
Scott
2003 Tahoe Stock
Old 07-02-2025, 10:19 AM   #585
raggedjim
raggedjim's Avatar
That's for sure! I'm always thinking "Well, if I'm ever going to do it now is the time."
At least most of the welding is done. Still have lots of areas to grind and fill. Also need to flip the cab and clean up the bottom. Not shooting for perfect but I want to get all the old caked on mud, grease, and undercoating scraped off.
Old 07-02-2025, 10:22 AM   #586
loudchevy
loudchevy's Avatar
Yup, Might as well!
Scott
2003 Tahoe Stock
Old 07-12-2025, 07:36 PM   #587
raggedjim
raggedjim's Avatar
Finally flipped the cab, it was very easy, I don't know why I worried about it so much.
Bottom has thick mud, grease, undercoating combo.
Old 07-12-2025, 07:41 PM   #588
raggedjim
raggedjim's Avatar
Spent some time scrapping and finally hit it with phosphoric acid.
Old 07-12-2025, 07:44 PM   #589
raggedjim
raggedjim's Avatar
Then I sprayed the bottom with etching primer and then 2 coats of bed liner. I will probably hit it with one more coat before flipping it back.
It's not perfect but it works for me!
Old 07-13-2025, 11:29 AM   #590
hewittca
hewittca's Avatar
I'm enjoying these updates and motivation because I'm about to embark on the exact same mission with my cab. The underside looks awesome to me! Nice work.
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10 | Oscar the 70 C10
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 07-13-2025, 11:46 AM   #591
7dee2
7dee2's Avatar
Looks great, good job!
Brett
66 El Camino: BBC, 4sd. Waiting for its turn.
67 Camaro SS: 67 Camaro Build
72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build
72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 07-13-2025, 07:09 PM   #592
raggedjim
raggedjim's Avatar
Brett talked me into it!
Old 07-15-2025, 07:52 PM   #593
raggedjim
raggedjim's Avatar
Well, I welded them shut...
Old 07-15-2025, 09:04 PM   #594
zicc1835
zicc1835's Avatar
I see AC in the future
zicc1835 is offline   Reply With Quote
Old 07-16-2025, 10:28 AM   #595
raggedjim
raggedjim's Avatar
Either that or a bunch of sweating!
Old 07-16-2025, 10:35 AM   #596
raggedjim
raggedjim's Avatar
While I have the cab flipped I am trying to do any work I can do to it to help keep me from having to work overhead. Keeping these noodly arms lifted up for hours plays havoc on my shoulders!
Old 07-16-2025, 07:52 PM   #597
raggedjim
raggedjim's Avatar
This is one of those areas. Cutting out and welding the upper windshield frame almost killed me. Would have been much easier and less burning hair if I had waited until I had flipped the cab. Live and learn.
Old 07-17-2025, 11:10 AM   #598
Roostre
Roostre's Avatar
This looks great! I was originally thinking about smoothing the tolerance gaps in my cab, but I've given that idea up as my project has drug out too long already.
I am also planning on tipping my cab to paint the bottom of it when I get to that point. The new floor in there has an e-coat on it, but I don't trust that to hold up on external panels like paint will. Although maybe I'll just scuff the e-coat and undercoat it rather than paint; that may be a viable option for me.
Roostre is offline   Reply With Quote
Old 07-17-2025, 02:27 PM   #599
raggedjim
raggedjim's Avatar
It feels like this one is dragging out, but the only way for it not to drag out is to ignore things and I hate to do that. I've always top-coated e-coat, not sure if you have to, but I always have.
2 guys can tip the cab easily. Good luck, Rg
Old 07-17-2025, 02:51 PM   #600
Roostre
Roostre's Avatar
My day job is for an agricultural equipment manufacturer. We have several suppliers that provide parts with e-coat. We always paint the parts even if they are meant to be black on the finished product, and I was told that it is because the e-coat does not hold up well to UV exposure. So my intention is to topcoat any e-coat parts that are exposed to the elements. Example: My outer roof skin was e-coated and I painted the top of it, but did not paint the bottom of it because it is sealed within the roof.
