Old 08-01-2025, 09:37 AM   #1
truckeroy
truckeroy's Avatar
1984 Chevrolet truck rear axle identification
Can someone please tell me what the gear ratio is on this 10 bolt? Stamped code is RUB. Thanks
1948 Chevy 1/2T
1964 Chevy 1/2T stepside short bed
1939 Pontiac coupe Street Rod
2005 GMC 1/2T short bed
truckeroy is offline   Reply With Quote
Old 08-01-2025, 10:19 PM   #2
MJN
MJN's Avatar
Re: 1984 Chevrolet truck rear axle identification
No RUB code in the parts book for 1984, can you post a picture of it?
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 08-02-2025, 08:01 AM   #3
truckeroy
truckeroy's Avatar
Not sure how to post pictures.
1948 Chevy 1/2T
Old 08-02-2025, 08:28 AM   #4
truckeroy
truckeroy's Avatar
I think a picture is attached
1948 Chevy 1/2T
Old 08-02-2025, 07:45 PM   #5
MJN
MJN's Avatar
That code doesn't show up for 1984 trucks, according to the GM parts catalog. RUB was used from 1978-80, 2.73 ratio axles. You could pull the cover and check the date stamped in the ring gear and also verify the ratio at the same time.
'17 GMC Yukon XL
VCCA member #58596
Old 08-02-2025, 08:02 PM   #6
Keith Seymore
Keith Seymore's Avatar
And change the fluid.
And change the ring and pinion to a 3.42 ratio.
(I'm kidding.)
(Mostly).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 08-02-2025, 09:56 PM   #7
truckeroy
truckeroy's Avatar
Thanks for the information. The guy told me it was out of an 84. I haven't seen it yet. I wanted to know the ratio before driving 50 miles. Your correct, it's not an ideal ratio. I have a 3.73 stock rear axle now with a Saginaw 4spd. A 308 would have been nice.😀 I don't know if this ratio will work. Thanks again.
1948 Chevy 1/2T
Old 08-02-2025, 11:06 PM   #8
Getter-Done
Getter-Done's Avatar
This code may have been stamped Friday before 5:00pm .
I worked at a manufacturing plant and this stuff happens.
The early bird gets the worm,
85 Chevy K-20
Old 08-03-2025, 11:19 AM   #9
Keith Seymore
The engineering specifications guys were not above a bit of humor; we had a little firecracker that had design/release responsibility for the engine cooling system. Her name was Pam something or other.
The specs guys took the biggest radiator she was responsible for and assigned the pick code "PAM" to it.
K
1979-1986
1986 - 2019
