#26 | |
![]() Join Date: Jul 2021
Re: Made my first pass down the strip.
#27 |
Cracked my new plastic hood and bent the hood hinges. I am in Michigan, and drag racing season is about over for us
#28 |
![]() Join Date: Jul 2015
That's a total bummer.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
#29 |
Made it to the track yesterday. I'm not sure if it was just the weather, but the traction was not there. After pulling some pressure out of the tires, and some timing out of the motor, I was able to leave softly and run an 11.63 at 117. The online schedule shows that was the last Wendesday test and tune of the year, and the guy at tech was unsure if it is or not.
I am thinking a good upgrade for next year is some Caltracs. I am just not sure if they will help enough or if I should ladder bar it or 4 link it? Here is the best time slip from last week and this week. I know the reaction times are embarrassing. I waste the good reactions on crappy passes |
#30 |
Cal tracks would be a good upgrade. Ladder bars would not be hard at all to build your own set if you have the ability. Helped a buddy put a set on his truck, pretty simple design and they worked wonders on axle wrap and wheel hop. If you can tame your rear end and get your 60ft time down you'll have something.
#31 |
My best 60ft was 1.62, which I feel is good. I just want to get to were it can do that more consistently.
I have some work to do before the season opens up next year( and about 6 months to do it). Still looking for a 2wd short bed standard cab of this generation to build a real drag truck out of. |
#32 |
Well that's some bad luck. I forget that there is a racing section here. I like drag race threads. I don't understand your numbers though. I have never seen a time slip/drag strip set up like that. I'm sure it's still fun just the same. I love the Chevy orange engine. I'll bet it will keep getting faster as you get it dialed in.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
#33 |
Yep, next year.
Got the all terrains put back on it for now. |
#34 |
Well, new PB, but still cannot get it to 60ft. Need to work on f/r weight bias.
#35 |
Man! The MPH is there but that dang 60ft is killing you.
#36 |
![]() Join Date: Mar 2008
It looks like a 10 second time slip isn't far away. That thing is moovin out for a big ol truck.
NHRA Super Street 469C It only runs 10.90 at 156 mph I was Dragtruck when Dragtruck wasn't Cool! |
#37 |
Got a couple 10 second time slips today.
This is the new personal best. Switched from a 17x9 rear rim to a 15x10. Tires where of similar sizes. Going back to Milan tomorrow to watch Hot Rod Drag Week. |
#38 |
Thats awesome!! Congrats. Enjoy drag week too, I'm jealous.
#39 |
Yep, 2 good days at the track.
#40 |
I moved my battery to the back of the bed, installed a 33% bigger meth nozzle, and changed my Caltracs from half a turn preload to 2 turns of clearance. Also lowered the 2 step to 2000 RPM so it would stop pushing
First pass out went well. So decided to hit it harder. Pulled out the last 5 degrees of launch retard out and made a second pass. It went better. So now that it was hooking on full timing, I decided to add some total timing in. Went from .6 to .5 degree retard per psi of boost. So 1.3 degrees of advance. Started loosing the tire on the hit again, but picked up some mile per hour. |
#41 |
Second to last test and tune of the year.
#42 |
Getting the itch, but winter is preventing me from even working on it. Signed up for a drag and drive event in August, so need to make this thing legit before then.
#43 |
Threw it on scales today. Weighs 4580 lbs. Hopefully I can shave down on that this year.
#44 |
She needs a diet for sure! Good luck with the addiction!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
#45 |
I have some plans for it, but wanted to make a few passes to try out some other things I changed already. Track opening keeps getting delayed. IHRA bought it and is dumping a bunch of money into it.
#46 |
I have started doing some work on the truck. Redid the front suspension and brakes Managed to lose about 200 Lbs. Still have a steering to install in place od the steering box and linkage. I have together cage done first though.
1972 Blazer- 1988 Fiero- 1976 Cobra II- 2004 Sierra "drag truck"- 1999 Corvette FRC- 2014 SS- 1965 Barracuda- 2019 Ducati Hypermotard-2003 Kawasaki Z1000- 2022 Silverado 2500- 1985 ATC350X- 1986 ATC250R Last edited by litebulblsc; 07-16-2025 at 04:33 PM. |
#47 |
Had "day zero" of the Drag and Drive I will be participating in today. 7 more days of driving over 1000 Miles and racing (1/8 mile) 5 of those days.
Called Sick Michigan Miles if anyone is interested in looking it up. I teched good for 6.40. I ran a best of 6.66 today in testing
1972 Blazer- 1988 Fiero- 1976 Cobra II- 2004 Sierra "drag truck"- 1999 Corvette FRC- 2014 SS- 1965 Barracuda- 2019 Ducati Hypermotard-2003 Kawasaki Z1000- 2022 Silverado 2500- 1985 ATC350X- 1986 ATC250R |
#48 |
Hell yea, I'll watch for you. I always like following along on the SICK week drags and drives. I want to do one soo bad!
#49 |
Day 1. My car number is 80. Puts me in 27th place
#50 |
You largely won that race at the light (i.e., .4491 delta) and your truck added to it (i.e., .0812)! Nice reaction time! Good luck and safe driving today!
Travis' Tribute Truck - 65 C10 Frame Up Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=495073 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
