Old 08-21-2025, 04:43 PM   #5426
72c20customcamper
72c20customcamper's Avatar
Re: What did you do to your truck today.The 3rd chapter
Cleaned up the transmission cross member and engine perches not to often do you come across a 57 year old vehicle where the frame parts look like new . I scratched the paint getting the goo off still going to scuff and paint them though
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 08-21-2025, 06:57 PM   #5427
Extended Power
Extended Power's Avatar
Made a wood grain pattern using my old stock instrument panel.
They are not the same as an aftermarket instrument panel.
I will make another one at some point. (When it bothers me enough...)
"If it ain't broken, fix it 'till it is!"
Extended Power is offline   Reply With Quote
Old 08-21-2025, 09:04 PM   #5428
WHYBYNU
WHYBYNU when old will do
WHYBYNU's Avatar
Well after 18+ years my Flowmaster 50's mufflers finally needed to be replaced. One of the internal baffles broke free and rattled like crazy. So new ones got installed today. Let's see if they last 18 years.
71 Cheyenne super
2 tone green and white
ZZ6 - Th350
4/6 drop
20x8.5 / 20x10 Billet Specialties
WHYBYNU is offline   Reply With Quote
Old 08-21-2025, 09:30 PM   #5429
cj847
cj847's Avatar
I decided to dress up my center caps. I am 6 lug 2wd and have rally wheel center caps on some kind of old modular wheels. The previous owner had covered the 4x4 with a piece of black ABS that looked OK. I shopped online and a set of stickers that would fill the entire dia were $40 and a long wait. Then I remembered my son-in-law has a 3D printer. This is what I came up with. One pic is the wheels currently on the truck. The other is some Rally wheels that I have painted white and plan to install soon.
cj847 is offline   Reply With Quote
Old 08-22-2025, 12:31 AM   #5430
'68OrangeSunshine
'68OrangeSunshine's Avatar
Nice look.
Old 08-22-2025, 08:10 AM   #5431
zicc1835
zicc1835's Avatar
Originally Posted by RodnRudy View Post
I "winterized" Old Red today. Replaced the "mags" with the ralleys and while I had the rear wheels off I replaced the brake shoes and painted the new drums I bought at Auto Zone. I've never liked the drums I got at NAPA, they were not concentric, and causing a pesky vibration. I'll finish buttoning her up tomorrow after the paint on the drums is dry and take her for a test drive.
If I may ask what’s your plan with the mags ?
zicc1835 is offline   Reply With Quote
Old 08-22-2025, 12:38 PM   #5432
72c20customcamper
Crossmember painted up today . And I got tired of working around the front clip just makes life so much easier with it off
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-23-2025, 08:22 AM   #5433
Jiggers72-GMC
Great work Mark, that's gonna be so nice ........ looks like your project has snowballed
Jiggers72-GMC is offline   Reply With Quote
Old 08-23-2025, 02:37 PM   #5434
72c20customcamper
Not really I knew what needed to be done as I went down the same rd last year with the 72 . Would have been a little easier and less expensive had I just bought a 350 but what fun is that
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-24-2025, 03:37 PM   #5435
awryexperiment
I decided that I'd had enough of passing-out behind the wheel and that constant ticking noise that drove me nuts.
Driver's side was quite a bit more cracked than I realized. Passenger side had one rounded bolt and one rounded nut, so I decided to grind off what was left of the bolts and try to extract the bolts from the head after the manifold is removed.
1972 Chevy C-20, LWB, Fleet, 350, SM465 4-spd, dark olive green, stock, restored.
awryexperiment is offline   Reply With Quote
Old 08-24-2025, 08:24 PM   #5436
zicc1835
zicc1835's Avatar
Attachment 2430154
Attachment 2430155
good luck getting them out soak & then heat
Old 08-29-2025, 07:36 PM   #5437
Cooter!
Talking Re: What did you do to your truck today??
Put a different set of wheels on just to play around These truck use a MAX front-space (wheel/tire combo face down measured from the floor to the WMS) of 6.75" front and 6.25" rear. They will tuck and turn completely at full suspension compression. If you did drop spindles that will be even less because they make your front track width wider.
Bassett Inertia Advantage 15X9 3"BS 265/15-15 and 15x10 3BS (should have got 4"BS to tuck better), 295/50-15
I like these Rallys I have too but time for a change and they needed a 1.5" front and 1" rear spacer to look right.
17x8" 245/45-17, 17x9" 255/50-17.
Cooter! is offline   Reply With Quote
Old 09-01-2025, 01:41 PM   #5438
ivory68
ivory68's Avatar
I installed a new heater box and heater core (brass/copper). I didn't realize that the plumbing was backwards (for over 35 years!), as previous owner had done a fiberglass repair to the cracked housing. I used a set of LS conversion heater hoses. I really liked the 90 degree bends that came with them. The routing looks so much cleaner.
ivory68 is offline   Reply With Quote
Old 09-01-2025, 02:30 PM   #5439
3757chevy
3757chevy's Avatar
Originally Posted by ivory68 View Post
I installed a new heater box and heater core (brass/copper). I didn't realize that the pumbing was backwards (for over 35 years!), as previous owner had done a fiberglass repair to the cracked housing. I used a set of LS conversion heater hoses. I really liked the 90 degree bends that came with them. The routing looks so much cleaner.
Looks good!
'67 Stepside (bought 1997-sold 2021-partially bought back 2024) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 09-01-2025, 02:56 PM   #5440
lil hoodlum
lil hoodlum's Avatar
Nice looking engine bay!
1968 C10 327, 3 speed manual, LWB stock height daily driver.
1968 C20 327, 4 speed manual, LWB stock height custom camper with heavy duty leaf springs rear, 50th anniversary edition. Hoping to press into daily drive status soon.
lil hoodlum is offline   Reply With Quote
Old 09-01-2025, 05:58 PM   #5441
zicc1835
zicc1835's Avatar
Very nice
Old 09-01-2025, 10:17 PM   #5442
67swb72klb
67swb72klb's Avatar
Put these filler panels in last week and a new alternator the bearings were getting angry...
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 09-01-2025, 10:49 PM   #5443
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Nice panels! I want to do this, but they aren't (supposedly) made for AC trucks. If I still had access to a brake, I'd bend my own. Just need reliefs for the AC stuff.
~Steven
Simi Valley, CA
Old 09-03-2025, 01:06 PM   #5444
ohboy321
ohboy321's Avatar
Today I finished my disk brake upgrade project by installing a steering wheel I restored 5 years ago. I could not have completed the project without parts and information I got from this forum. My drum brakes worked okay, but the disk brakes are much better.
Steve/NH
1967 K10 327 Short Bed Stepside
ohboy321 is offline   Reply With Quote
Old 09-03-2025, 01:24 PM   #5445
72c20customcamper
Lightbulb Re: What did you do to your truck today.The 3rd chapter
Some progress hopefully have it done for C10 meet in Nashville in oct . If not I’m sure I’ll be able to take it to the C10 Fall Revival mid October.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-03-2025, 04:25 PM   #5446
68isgreat
I finally got my newly 350 tbi crate motor running right. I've spent the last couple weeks pulling my hair out as it stalled and died when I put it in gear, and ran rough during acceleration. I finally got it all fixed but man, what a pain! The fuel pump relay wasn't getting power, so I ended up tracing all the wiring from the new ecm harness I routed through the cab, which meant taking the cab partly off to check for shorts or broken wires. Nothing. Then I checked the fuel pump with a jumper, and it worked good. Then my neighbor suggested pulling the pump anyway, and it turns out the wires were barely connected to the terminals inside the tank. Good grief! Now it doesn't stall. It was still running rough however, which was two things: My temp exhaust had leaks which was messing with the air/fuel ratio, and on a whim, I took off the 1" throttle body spacer I had installed, and that smoothed it right out. The computer didn't like that spacer! So word to the wise, if you're doing a tbi conversion, keep it more or less stock, and make sure all wires are tight, and your exhaust system is tight as well. Now it runs great! Got the doors and fenders painted, and working on the bed next. Almost done!
68isgreat is offline   Reply With Quote
Old 09-03-2025, 05:42 PM   #5447
Speedracer39
Speedracer39's Avatar
First time out of the garage in 2 years.
Speedracer39 is offline   Reply With Quote
Old 09-03-2025, 06:39 PM   #5448
'68OrangeSunshine
That is a really nice Wheel restoration.
Old 09-03-2025, 10:08 PM   #5449
SRU1436
Looks good, who makes the distribution block?
SRU1436 is offline   Reply With Quote
Old 09-04-2025, 04:14 AM   #5450
ohboy321
ohboy321's Avatar
I went with The Right Stuff proportioning valve: https://rpui.com/-Repair-Parts-71-72...isc-Drum-PVK41
Braking tests so far including hard stops are going well. Once the new parts are broken in I will try locking them up to see how that goes.
Steve/NH
